0 Members and 1010 Guests are viewing this topic.
Zeitmaschine
Quote from: Dog-One on July 08, 2015, 05:58:29 PM
Not really! The magnetic field forms a current. The current in the resonant circuit is primary !!! Not shakes these grenades. It is not necessary !!! There Reel 1/2 ratio of the two coils. Ie removal rates of 40 meters, inflating circuit 20metrov. Beat the electric field goes under the same electric field. We charge an additional electron loss of the oscillatory circuit. We start moving charges. Magnetic-hearth result of the motion of the current. But! We need to pay attention to the electrical discharge at the time of Tesla's current movement. Of course the system will work only with pure sine wave vyhode.Kogda particles move !!! They need to polarize correctly and get the effect. In other words, you're rocking the swing oscillating circuit.
And there are no secrets! Dispersal of the current pulses in the circuit. This is the secret that everyone is looking for, but for some reason can not guess. Strange!
That's exactly what I meant by saying »getting lost in tons of gibberish«
How to »charge an additional electron loss«? ::)
Quote from: John.K1 on July 08, 2015, 04:15:41 PM
What I could catch with my poor Russian from the Ruslan's last movie:
7. The Grenade coil is NOT a Kapanadze coil!!! It is just regular transformer
Then he knows the principle of work of the Kapanadze coil, so he can say his is NOT? Then why is he not simply replicating the Kapanadze coil if he knows how it works?
NickZ
  Well guys, it looks like we are being left behind in Ruslan's dust.
  Now how the puck are we going to keep up with him?  He said, don't build anything, just learn by watching and reading.  Jesus~ what a suggestion.  He also says: Don't ask me questions.  And I tell you no lies...  (my edit).
   So, we make an exact replica of the blue TK coil, and now it happens that although it's just like TK's coil, it does not work the same.  Although TK's blue coil did not have or use an 24 turn inductor coil wound on top of the 168 turns output coil.  Or did it, I can't remember. But, I think that it did not. And, it didn't use a Kacher circuit, as far as can be seen. Therefore it may not have worked the same, even though it looks similar. Who knows...
   So, now everything has been changed, except the coil that is now not a TK coil. It's now the newly named Ruslan "collector coil" The other two coils are LC tank resonant circuits.
   In my way of thinking, the "collector coil" (grenade output coil) is connected directly to the yoke's 28 turns secondary coil. Not how it was originally made, isolated from direct connections to anything. Therefore this collector coil is NOW also an inductor, as well, just like the 3 turns coil going to the 0.47uf tuning cap and then to the 24 or so inductor coil wound on top of the output coil. If this 3 turns yoke/inductor circuit is disconnected, my system runs about the same as with it connected. Not so if the "collector coil" is disconnected from the yoke secondary coil.  My system will not run, no bulbs will light.
  Therefore, this "collector coil" is not working like on Akula's first device where his big output coil was ONLY connected to the bulbs, and was otherwise isolated from a direct wired connection to anything else, other than the optional earth ground line, at one end. THAT, was a collector coil, which is not connected directly to anything else, other than the bulbs and to ground.
  So, should I take Ruslan's advice, and just study and learn but not build anything that I don't fully understand?
Even though Ruslan did it, with Oleg's help,  Or, maybe Oleg did it, with some help from Ruslan?  To show and tell.
AlienGrey
It's getting interesting isn't it ?
It's 5. He is not using Kacher./Katcher  He is using SG based on TL (pulses)
so is SG = Synchronized Gating ?
So what is TL ?????   Totem pole Logic ?????  ,   who knows
Wasn't TK talking about this a while back with his 4046 and a ic555 ? Yes he was, Have you ever done a math's Uni course, you might have noticed some large numbers divide down to a small number with no remainder, pick one and play with it, then it will dawn on you what's happening. I think it's called resonance !
Also one of the Donald Smith vides he displays a device where it runs all 3 or 5 hours till he turns it off, at one stage he gets a loop of wire waves it about and asks what advantage using a wire loop would have if wound in a transformer, well it would not produce any voltage. You would do well to watch some of his videos on you tube, very well in fact to leave no stone un turned in the quest for answers.
Also does a horse push a kart or pull it, here, think of a kid on a swing.
And, if a compulsive liar said every thing he said was a lie would you believe him ?
Hoppy
Quote from: AlienGrey on July 09, 2015, 02:25:09 AM
Liar or not, as to whether there is any substance behind his statements is simply a matter of opinion. He will probably eventually fade off the scene as his detractors get even more critical of his presentations and 'teach-ins'. Nobody has yet shown good sound technical evidence that they have replicated a Kapanadze, Akula or Ruslan type self-runner, so its simply the case of a continuation of the blind leading the blind, based on personal beliefs.
a.king21
 AlienGrey:  do you have a link to the Don Smith video you are writing about?
