0 Members and 90 Guests are viewing this topic.
Dog-One
Quote from: Tomtech29 on July 10, 2015, 10:36:47 AM
He was referring to coil L1 = 18.7 meters and 37.5 meters L2
from what shows they are not so wound as he claims
You are correct, they are not exactly the same.  The pattern is nearly correct but the number of turns will take some work to find yourself.  Stick with the 48x48x24x24x12x12 pattern for the grenade coil.  Get it wound, strip it all off and measure it.  Once you have done that, cut another piece of wire at exactly half the length and use this piece for the induction heater coil.  You will find the induction heater coil wire length forces you to make at least three layers as I noted previously.
T-1000
37.5m = full wave -> 8MHz -> 1/4 for Tesla coil is 2MHz
18.7m = half wave for signal on inductor, to get into bearable kHz range for induction heater you have to divide Tesla coil wavelength by 50 or 100...
Void
Quote from: Dog-One on July 10, 2015, 10:41:31 AM
Dog One. Yes, we determined this a long time ago here in this thread, that to have the so called 'inductor'
coil at one half the length of the grenade coil you will need three layers, but Ruslan only appeared
to have two layers at the time. Very odd...
All the best...
NickZ
  quote from Void:
  "Hoppy: You must have eagle eye vision, as you see wires and batteries that no one else can see".
         end quote.
   Yes, I was wondering about that myself...  as all I see from what he mentioned, are pieces of chairs, weed stems, wire clipping, normal ground wire terminal ends, cut weeds, etz...
but,  no batteries, x-wires, and such.
   So, I'm still waiting to be properly shown and proven what all of this fake business is about.
   However, IF Ruslan has really admitted to showing non working faked devices, we need to know about that, as that is not a small detail, to not waste more time following the wild goose chase.
Tomtech29
Dog-One
so I made a coil as you say only that I L1 2x047uf resonance capacitor 15kHz and at L2 = max amplitude 1.3Mhz from what I saw it ruslan says that the size of the toroid is and will działeł so small like this:
because it's just a low frequency does not play a role until the amplifier it and these transistors can you lower
