0 Members and 54 Guests are viewing this topic.
Dog-One
Quote from: NickZ on July 16, 2015, 01:56:37 PM
  I just hope that the push-pull circuit can be substituted by something much simpler to replicate, even if it's not stable at first. As I have my doubts that the push-pull system with all it's needed complications, is the only way to go.  Or, to use something ready made commercially, like this PCB, below, or, a cheaper made in China knock off.
I can tell you as a matter of fact, a simple sine wave signal generator and a decent single channel audio amplifier works perfectly.  Then all you need is a current sense transformer around one lead of the induction heater coil to find the crossing point and fire your Tesla driver.  Piece of cake.
NickZ
  If you think that it might work, yes, but, a bribe is not what I had in mind.
More like soften to soften him up a bit, to spill the beans.
   How does that old saying go... A way to a mans heart is through his ...
  Good thing that Ruslan is not reading these posts...
   Hey Dog: If you think that your approach would work, why don't you try it out first, as it your idea.
lost_bro
Quote from: T-1000 on July 16, 2015, 01:56:18 PM
As the basics is understood we can continue on more complicated ones. :)
The PLL is required on changing conditions such as changed loads and changed earth ground conductivity which affects optimal frequency. So the circuit has to do same autotuning as FM radio does.
Here is one of versions with all parts together: http://imgbin.org/images/24785.jpg
Good day T-1000
This version is the *single shot* pulse generator, ie: the base/gate of VT3 receives a syncronized *single shot*  narrow (n.s.) pulse.
This was used in his less recent older version of his device.
Now he says he is utilizing *multi-shot*/packet type pulses for better effect.
Do you have access to the newer circuit topology?
take care, peace
lost_bro
Zeitmaschine
Quote from: NickZ on July 16, 2015, 10:58:05 AM
You guys want to try to replicate Ruslan's latest driver circuits???  Well, good luck with that, as it happens to be the worlds most complicated of devices, and possibly one the best kept secrets, still.
Ask yourself the question: Could Ruslan make a three-phase version of his device, like Kapanadze and Stepanov?
I don't think so.
Three times all parts and driver circuits, perfectly synchronized with each other? What would it look like? :)
GeoFusion
Hi there guyz
yes I can still provide that simple circuit of TL witch i used, but As I see
I will be building these Oleg Circuits.
T-1000     Thank you for the Oleg Pdf files, and enlightment and everyone els that is helping
putting thought to this and effort.
For Push Pull and Tesla coil driver with on/off control TL494/.
yes, the frequency will be different in each setup.
The Tesla coil Circuit setup reminds me of his first replication of the Dally Device,
It's the same one used for impulse on Coax, but now implemented on Tesla coil. hmm
This one  http://imgbin.org/images/24785.jpg
Is a worth the while shot to see if it will ;), will try out.
I will try to build these circuits for test.
Something is starting to make sense now.
The packet pulses is important here to fit in squar wave pulses, in my understanding,
Syncing together and locking them.
This also opens up a  new doorway for Vasmus Device understanding, It's basically same thing,
Tesla Kacher + impulse pushpull circuit on coiled plate and must sync.
Or it must be using a Thyristor for Squar pulse on reciever coils.
For what Ruslan is using now is much more complex, that is true,
So Tesla coil has to be drivin to send packets and has to be synced with Push pull in resonance.
amazing :), hmm..lets see how this works out.
Bringing Voltage and Amps together as one. To resonate.
Visiting Ruslan to go see his device would be a wondrous advanture,
It would help to see and understand his device better, hopefully.
Ok Guyz,
Cheerz~
