0 Members and 346 Guests are viewing this topic.
Hoppy
Quote from: John.K1 on July 20, 2015, 06:25:35 PM
Soon Nick ;)
Watching some of the Ruslan's video, I have more an more feeling like it is so primitive device. So, what I got from the movie today?
  It looks like tesla must fire its pulses around the peak of the positive halfe of the sinus wave on the coils.
The diode(s)  play important role here. Coils are like a capacitor which you are charging. Did you try to charge a capacitor with Tesla coil?  One end to tesla, one end to gnd?  You need to put there a diode. The same here.
The inductor is as a magnetic field pump.
Looking back over the other long running Kapanadze thread, I found this interesting post below from Ctglabs on page 1. Now just supposing the wire could be coiled up to get the effect while being pulsed to ground at the AC end. ;D   I think Kapanadze used two ground connections on the 'green box' device. Are the Kapanadze box devices so primitive they will make you laugh??
Hi Bill,
This immediately reminded me of something I read on keelynet many years ago, just found it:
http://www.keelynet.com/energy/aethrtap.htm
Not exactly the same, but pretty much similar:
"He showed us a diagram of this very interesting idea that he says would allow one to pull energy from either the earth or aether.
It required the use of a one mile wire, laid out in a straight line. I asked him if it could be wound up and he says he does not think it will work if NOT stretched out.
So, you take this wire, support it from the ground by non-conducting 18" high standoffs and stretch it over the one mile test area.
On one end you put an AC power source, with the ground wire connected to Earth ground, and the high side connected to the wire.
On the opposite end, you tie in a string of lamps. One side of the lamps are tied to the one mile hot wire, the other side is tied to an earth ground connection.
Vic says you stay at the AC power source side of the wire while watching the lamps with a pair of binoculars. When you switch in the AC power source, the lights will all light up.
Now comes the weird part. If you very rapidly transfer the one mile wire connection FROM the AC source DIRECTLY to the earth ground, the LIGHTS WILL STAY ON! Or so Vic tells us.
I am told there is a patent on this and seem to remember having seen one like it somewhere before. It is interesting to note that Thomas Henry Moray's Radiant Energy Receiver also REQUIRED the use of long wire antennas. The 18" height is a curious requirement unless there is something really odd at this level above surface. "
Regards,
Dave.
Dog-One
... will appriciate if anybody here can share your cheaper supplier, if any ;)
These part numbers from Mouser are working plenty good for me:
80-C4BSWBX3470ZAFJ
80-C4BSWBX3330ZAFJ
80-C4BSWBX3220ZAFJ
80-C4BSWBX3100ZAFJ
Had to get a few more than I initially estimated.  You can hook them in parallel and series combinations to get pretty much spot-on values.
Not sure if they are cheaper than your eBay supplier, but they do work and work well.  Nick would like them because they make BIG sparks.   :P
Tomtech29
NickZ thanks for the specifications of the transistor 2sk1162 I have not found fortunately not the same, I used FQA11N90.
- First test went quite well (where irfp260 is a powerful transistor is damaged) I have to be careful with higher voltage.
piecing Push-Pull system will have to wait your turn present I do not have these parts,it is worth checking how it will be run and whether it differs from the standard TL494 which have now.
It remains the fundamental principle on alignment coil It is no longer strong need to try different methods.
https://www.youtube.com/watch?v=IiKIlzpbCBk
Dog-One ,it seems to me that the appropriate frequency tuning will be an interesting phenomenon ,when changing the saw as the waves is spreading and also rendering shape changes with this type of signal meet for the first time
another experience that discovers a piece of the puzzle.
the next question is where are these diodes which is said ruslan?
I suppose that here:
It is in the wrong direction what you think?
John.K1
Tomtech,
I don't know, but I would like to see a saw shape from the Tesla coil :)
Tesla always produce the sine wave.  You only swith the tesla on and off at the right time. It gives you that packets of pulses. This is how I understand .
Grumage
Quote from: Hoppy on July 21, 2015, 03:32:44 AM
Good afternoon Hoppy.
I'm of that age where I seem to be forgetting more than I learn, however, as soon as I read your post the name Frank Prentice popped straight up !!   :)
http://www.rexresearch.com/prentice/prentice.htm
Might just be tapping into Ley lines !!    ;) ;)
Cheers Grum.
