0 Members and 368 Guests are viewing this topic.
Tomtech29
NickZ
as you can see the cameraman not to burn tester under HV only almost jumped out of the screen ;D
I can not understand this concept of connecting a pancake just one case for real conductor (Erase that it was another invention for transformation) ;)
cool fireworks (Ta.TA.ta) :D
nelsonrochaa
Quote from: NickZ on August 02, 2015, 02:57:22 PM
   I don't know about others, and their Kacher drivers, as everyone is using a different set up. I use a transistor for my Kacher driver circuit. But, I think that as we here on this thread are all using a relatively shorter Tesla coil secondary than normally used, the driver requires more amps to push it to the right frequency.  At least it does on mine.
   I've mentioned that the Exciter circuits are much more efficient, drawing much less power, but I think that it takes some amps and not just fluffy voltage to cause the right effect on the Ruslan/Akula devices. As they are higher output devices (up to 4000w output), if you're lucky enough to see it, that is.
Maybe i have luck to one day see reasonable values like you talk , maybe is only a question of design to this output  values  .
See you need a 4000J for second to output in a second the 4000W output not counting with losses, so if you output 400V over 4000W in the resistive load you have to obtain pulses discharges of about 4 amps for second to obtain your 4000W output.
If you use a normal battery under normal circumstances you will need a huge current discharge from battery (166A) and this not explain the output of circuits like akula and others show ... or the caps discharge are not full with normal currents ;) like people expect.
Good luck
nelsonrochaa
Quote from: Tomtech29 on August 02, 2015, 03:23:51 PM
NickZ
Actually its me and i take the static discharge on the box :)  . About the pancake is connected on the antenna of radiant output not in the box .
If you understand portuguese you will see that video is shooted in descontration between  friends and a dedication to a friend mine Helio that are in UK :)
nelsonrochaa
Quote from: Tomtech29 on August 02, 2015, 02:57:30 PM
Hi Nelson,
Thank you for share a device that you have a very nice work- congratulates idea!
it seems that the direction that you have planned is a surprising level,I would like to ask how long you worked on overall system?
or in another project you will for some purposes is HV,will serve a useful function?
how long will shine this 60 watt bulb? (without source)  :P
Thanks ,
Of course have HV purposes too :) like you talk about the pancake coil i able to connects how many coils i want and rectified to 600v without compromise the other outputs so i think is possible get some usable function .
About the source give your shot ;)
Tomtech29
Amazing is the presence of persons from different parts of the world.
language "portuguese" as well as many others are difficult to learn suppose.
Now with your translation: (I do not understand this word) "video is (shooted) in ?descontration?"
