0 Members and 259 Guests are viewing this topic.
magpwr
Quote from: nelsonrochaa on August 02, 2015, 09:05:36 PM
Hi , Magpwr
the transformer is not center tapped :) either the transistor is a high voltage  on circuit exciter that i show .
Seems that you are think in a push pull configuration and is not :)
With ground connection on circuit, the caps will charge almost instantaneous with 1000v 4uf the beauty is in a normal scenario it will blow the my caps, because the value in the caps that i test is rated at 400V but it not damage with 1000v :) working several time.
But is another story.
good luck for you work
hi Nelson,
May i ask are you using some kind of captor to meddle with the Lenz's law maybe to counter the current drawn by circuit.
It would be great if you draw or show us your old circuit which create hv using low current.
My recent video Tesla Transponder in youtube "sanjev21" with circuit diagram provided was the only one which show current movement Around 7Amps to Earth spikes via clamp meter using only 2watt total power  later on with single nanosecond pulse with 300VDC provided by disposable camera circuit running on 1xAAA battery.But i have never tried to capture the current movement to Earth before.
Hoppy
Quote from: NickZ on August 02, 2015, 08:13:31 PM
   This is getting better by the hour, and Hoppy, doesn't even know what to make of it all.... he's looking for his magnifier, though.
Nick,
I don't need my magnifier for this device, as its fairly obvious how these two jokers powered it. This device does not even cut it when it comes to competing with Akula or Kapanadze.
nelsonrochaa
Quote from: Hoppy on August 03, 2015, 04:16:53 AM
Nick,
The obvious thing is not how the "jokers power it... if you know how it work fine :) . About competing with Akula or Ruslan , i simple never think compete with my device  with the others.
Hoopy you are only try to scratch but it ok , i like you work too.
good luck
Hoppy
Quote from: nelsonrochaa on August 03, 2015, 07:13:36 AM
good luck
Well, at least you demonstrated your device in a fitting light hearted manner. Let's see who else can work out how you keep it charged-up. No magnifiers needed.  ;D
nelsonrochaa
Quote from: Hoppy on August 03, 2015, 07:37:55 AM
Thanks but i only show the device in response to Nick sentence. the device is not yet finished , but maybe i shot a video when is finished and put in my channel.
About the driver hv that we talking where i can see the driver diagram ? Have a link with that only to see ?
