0 Members and 239 Guests are viewing this topic.
Tomtech29
Quote from: NickZ on August 03, 2015, 12:05:09 PM
  So, concerning the Kacher...  I just did quick test on my Kacher circuit, which is now running on 24v.  And I was able to light an incandescent microwave bulb, 220v, 20w, to about 3/4 brightness. The bulb is connected to the 168 turns grenade coil, but the grenade is not connected to anything else. So, just by one end of the grenade coil going to the small bulb, and the other side of the bulb is going to the 37.5 meter earth ground. The other end of the grenade coil is OPEN.
So, now the small bulb will light up fairly well, the bulb will not light if both sides are connected to the grenade coil.
The grenades' output coil is showing a reading of over 1000v+, when not loaded by bulbs, just from the Kacher's radiated output.
Nickz you still have some work to do, and one end of the 168 the same as going to the emitter connect to ground and 60 Watt Bulb 230V without any problem just lights it works for me in you will ;)
:D
and it is so much of this output Kacher guess some of 2.5kV or more of 9cm. coil length of 0.8 mm2 and  tested on 39 Volt the transistor 5200  works great and I'll add that to the ferrite rod there is a spark (It is so powerful "radiation") that burned me lamp CLF as I lay in the distance from the antenna of 20 cm.
what you see on the film unless the power of the bulb.
https://www.youtube.com/watch?v=8RUS4n73RTY
Dog-One
Quote from: Ruslan Kulabuhov
Значит немного поясню,как работают эти все системы. А принцип прост - ОЭДС и её использование. Бифилярная катушка , это дроссель для исключения индуктивной связи вмешательства в рабочй процесс нагрузкой и в тоже время емкостной заряд от ВВ в трансформатор. Скоро будет видео с выходом 50 Гц. Так как с Акулиной системой всё ясно и честно сказать очень муторно. Не стабильность и не рентабельность системы делает её сложной и не практичной. Всё намного проще , чем казалось. Мой вам совет ,перестаньте искрить по катушкам. Это не работает !   Искровой разрядник для гошения излишка и звона катушки . Всё просто тут. Главное включить мозги. Намёк:  У Николы Тесла не было диодов и транзисторов , а также радио ламп. Он всё делал на прерывателях. Значит , запуская в катушку 50 Гц переменного тока , ваша ВВ катушка должна генерировать импульс 5 кГц !!! Это точно проверено и опробованно ! Заряды пускаем на медную трубку вокруг бифилярной катушки ,заряжая её. Кому интересно ,наберитесь терпения. Закончу девайс и выложу схему. Боюсь что тогда Капанадзе начнут повторять каждый 5-ы радиолюбитель. Оно и хорошо...
So I will explain a little bit how these all systems. The principle is simple - OEDS and its use. Bifilar coil inductor is to avoid inductive coupling interference in the work process load and at the same time, the capacitive charge of explosives in the transformer. Soon there will be a video with a yield of 50 Hz. As with all Akulina system clearly and frankly very dreary. Not the stability and profitability of the system makes it difficult and not practical. Everything is much easier than it looked. My advice, stop by spark coils. This does not work! Spark arrestor for Goshen surplus and ringing coil. Everything is simple here. Main including the brain. Hint: Do not Nikola Tesla was diodes and transistors, as well as radio tubes. He did everything in the breakers. Then, starting in the coil 50 Hz AC, your BB coil must generate a pulse of 5 kHz !!! This is exactly verified and tested! Charges embarks on a copper tube around the bifilar coil, charging her. Anyone interested, please be patient. I finish the device and lay the scheme. I'm afraid that if Kapanadze will be repeated every 5 s ham radio. And it is good ...
Can someone post a link to this OEDS principal.  T-1000, do you know what he is talking about?   "ОЭДС"
By the way, here are a couple of videos that Ruslan has "liked".
https://www.youtube.com/watch?v=EpqDr8bybaE
https://www.youtube.com/watch?v=_LEGOmm4Vwg
Probably worth watching and getting what you can from them.
John.K1
Quote from: starcruiser on August 03, 2015, 01:12:37 PM
@NickZ, rectify it and charge capacitors, then run an inverter. This should allow you to loop and self run.
No it wont. It is not OU, yet.
magpwr
hi starcruiser,
Spoken like you are some kind of consultant for free energy device.
Do you have any credential to show us like your youtube video containing any kind of experiment for a start.
I got a small problem of trusting anyone eg:free energy consultant whom got no video at all.
Hoppy
Quote from: magpwr on August 04, 2015, 04:56:27 AM
hi starcruiser,
;D ;D ;D
