0 Members and 255 Guests are viewing this topic.
John.K1
Quote from: Hoppy on August 04, 2015, 12:27:55 PM
John,
You need a small battery in parallel with the cap.  ;)
Actually a battery and bulb only would work as well, doesn't it :)
magpwr
Quote from: John.K1 on August 04, 2015, 12:02:38 PM
Yep Hoppy , fully agree. On other hand , do you want to see how fast you can charge caps with HV, just build Komarov's device. I have made one and it charge caps instantly. I can have the 220V 2W lite on one end and it still charge output cap quickly to HV (several hundreds-depends on input V). I bought several DC-DC converters and tried to connect them to the output cap. Unfortunately it doesn't work that way. Need to figure out how to take that energy from the cap and not to distress the system. The thick lines in the schematic is the copper sheet (2x )- I have used brass.
hi John.k1,
There is only 3 solution which i think at the same time.
1)spark gap 300volts...470volts....1000volts from capacitor.The other end of spark gap is going to a hv capacitor.Think of it like a reservoir.
2)SIDAC little costly than spark gap which trigger from 90volts....200volts....450volts....I use this for my 1 wire powered flash and also spark circuit .Circuit shown in my youtube video:sanjev21.
But can be used as well.
3)If you say you are able to light 2watt 220volts bulb from capacitor.Then a suitable resistor maybe 2watt rated can be used to charge a another capacitor at a slower rate depending on the circuit current draw.
But the most important thing is what was the current draw for the hv generator circuit after capacitor is charged up or during charging in progress.
I did use disposable camera which can do 300volts DC even 400volts depending on the capacitor voltage rating.Once the capacitor voltage rating is hit it's internal current leakage goes up hence it will never get destroyed because disposable camera circuit transformer is of low current output.
disposable camera circuit-
80mA on 1.5volts AAA under no load.Under heavy load like pulsing from capacitor AAA battery can't handle hence it drops to 0.9volts at nearly 1Amps draw.
This is under 2watt with capacitor used for nanosecond pulsing.
NickZ
   John.K and All:
   And it normally doesn't work that way, as is shown in that diagram above, allowing it to self run itself. Otherwise it would have been shown to work like that, by now.
   Just look at the work the Igor Moroz has been doing over the years, concerning the feed back paths, and trying to make any driver/coil device self run.
  But obviously (at least to me), Nelson has found a way to get it to do just that, self run. And that is a VERY important point.
  I do trust him, and wish him the best. And I appreciate him telling us (me) about trying out different driver options, and such.
  Any other information, or your future improvement is more than welcome here.
  But, I'm hoping that Nelson will reconsider, not get insulted by the boring naysayers, and leave us due to that.
That would be a real "bummer".  Indeed!
Hoppy
Quote from: John.K1 on August 04, 2015, 12:33:57 PM
Not quite. The discharging cap needs to be switched into the battery and then the battery switched into the bulb via a DC-DC converter or inverter if a higher voltage is required.
John.K1
Hi Hoppy, "switched" you mean "connected" or "switched" as pulse switched??
Nick, It "DOES" charge the cap rapidly to many hundreds ant it is a fact observed by myself. The question is what I can do with that.
