0 Members and 410 Guests are viewing this topic.
T-1000
Quote from: NickZ on August 07, 2015, 12:34:40 PM
  Excuse me T-1000, but you've NEVER ever shown a self runner.  Nor did you or anyone else ever replicated that device later on, which needed not one but two signal generators feeding it power just to make it work.
The intention was deliberate not to show self runner. It was to show power amplification and we did in two methods. Unfortunately both are hazardous to health and we did not have the nuclear lab with equipment to continue safely. Later akula just took same methods and applied to copper wire. So here it gone with complete devices as you seen in history.
Why I am getting to that debate again, I am not sure but anyway, here you have the answer.
ariovaldo
Quote from: nelsonrochaa on August 07, 2015, 01:09:53 PM
Hi Nick ,
The circuit don't use that exciter but other circuit but basic is the same thing  . I build some circuits like a tools to test and study some behaviors, so this i like a tool for me .
I have other similar circuits but are identical in work process.
The circuit is basic even for the starters  and cheap to reproduce . Nick dont forget a thing , without the right tools like a scope it will difficulty to you tune your actual circuit or the circuit that i post. Is fundamental have the scope to things make some sense not only suppose or imagine how it work, but start understand how a single difference in capacitance in tank circuit , can real affect the circuit output or simple details can prevent the right work of circuit exciter .
I don't know everything and  will continue trying improve the outputs in circuit without the feedback stop is the reason to i say that is not yet finished, need to improved some aspects like suck more power without stop the oscillation.
If people have a bit attention at minute 13:45 of the video could see what happens when the feedback process stop, in input line of 9v battery soft touch,   i measure that with multimeter ;) and what we could see ?  28v in line input when start with 9v battery but simple short the input will interrupt the oscillation without and sinal of short circuit .
Nick i think i make my contribution about this , now i need to focus to continue my work . So much time lost in writing and discussions don't take me  to another level if you understand .
Maybe when i finished the unity i shot a another video maybe .
Good luck for everyone .
Obrigado Nelson!!
Ariovaldo
NickZ
  Hoppy: as I've mentioned my head is still spinning from looking at all the different designs that are out lately.
But, I'm not depressed, just intrigued.
   Tomtech: Although we may need much more info to do what you're thinking of doing, that diagram may be a good way to start.
The key unknown factor is a working feed-back path. As that is where all other Exciter/Kacher circuits have failed to self run.
   If there is no magnetic current circuit Yoke/grenade coils to heterodyne with the HV Kacher circuit, then it's a simpler way to go.
   We can now see that just with the use of a single transistor, and using a non push-pull topology driver circuit, can also work.
But, maybe not as well, or not with the same KW output?  But, it will self run, even without the push-pull magnetic circuit along side, and that is a very important point.
nelsonrochaa
Quote from: Tomtech29 on August 07, 2015, 12:48:19 PM
Nelson is very similar
the diagram above is a red marker electrolyte selected all the magic!
Hi tomteck29
People should understand first some main concepts , and seems most replicators of this kind of circuits not understood the process of  fill a capacitor without conventional  current .  Need understand first some important concepts .
I left a text not write by me , but very important lecture to people understand some points of max importance .
Hope some people understand this information because have some real important details need to understood .
A method and apparatus for extracting bidirectional EM wave energy from the vacuum through the scalar potential gradient across the terminals of an electrical source, collecting the excess energy in a collector without entropy, then separately discharging the collected energy through a load to perform work, without sending the load current back through the primary source against its potential gradient; i.e., against its back emf. Removing the load current from the source thereby substantially reduces the production of work inside the source to dissipate its bipolarity; said internal dissipative work being well-known to be the cause of exhaustion of the source's ability to continue to furnish emf to the external circuit. By reduction of its internal dissipation, the source is enabled to furnish more energy for dissipation in the external load than is utilized to dissipate the source internally. Hence the source is enabled to operate with an overunity operational efficiency. The system permissibly operates as an "open" system, and extracts and utilizes excess EM energy from a free-flowing external source (the flux exchange between the surrounding vacuum and the bipolarity of the source), hence it can operate at an efficiency greater than unity without violation of the laws of physics, in a manner analogous to but entirely different from a heat pump. In this invention, it is not the purpose of the primary source to furnish current and dissipative power to the external circuit. The bipolarity of the source is utilized primarily as a dipole antenna to receive the bidirectional EM wave energy flow from the vacuum, and direct it without entropy through a switching unit to the collector. Conduction electrons in the collector are temporarily restrained while being overpotentialized by the excess energy being collected upon them. The collector and its overpotentialized electrons are then switched away from the primary source, and connected across the load as a separate circuit and closed current loop. The electrons in the collector and their excess energy are then automatically released to flow as current discharge through the load, releasing their excess energy to perform useful work in the load. The collector is then switched away from the load and back across the primary source, and another collection cycle is initiated. Iteration of the collection and discharge cycles provides power to the load. Additional collection and smoothing capacitances for smoothing the iterations and furnishing steady power to the load may be added as desired. The invention violates the closed circuit practice of powering loads, but does not violate the conservation of energy law, the second law of thermodynamics, or any of the other known laws of physics.
nelsonrochaa
Quote from: NickZ on August 07, 2015, 01:21:40 PM
Nick ,
analyse this video , is the exciter of circuit diagram that i share , is more easy to see  and compare with diagram .
https://www.youtube.com/watch?v=bY3Mr2pAErw
