CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
b-VII. trying my hands on wm2d, Roberval Balance vs See-Saw Balance v24
lumen
Possibly something using a Roberval lift?
helloha
Quote from: lumen on September 15, 2014, 02:43:07 PM
i will try to sim this design first and let's see how it goes  ;)
helloha
b-VIII. trying my hands on wm2d, magnet affecting the weight of object 08
- sim an Electrostatic Artificial Gravity environment with sensor to control the strength of the electrostatic force
helloha
Analysing of Bessler's Clues 67.
< Little Info, Small Bearing Diameter >
"The diameter of the wheel is about twelve feet, and as well, the bearing was quite thin, about one quarter of an inch and only a sixth of its length was subject to friction." - eyewitness clue
"Through the centre of this wheel or drum runs an axle of about six inches diameter, terminated at both ends by iron bearings of about three-quarters of an inch diameter upon which the whole thing turns." - eyewitness clue
- collection of bearing diameter from eyewitness account
1. quarter of an inch
2. three-quarters of an inch
- based on above, although slightly different reading from eyewitness's account, but nevertheless the common factor for the bearing is the small diameter
- the diameter of the bearing is very small, if compared to 9-12 feet diameter wheel (also take into consideration that the wheel, including all the weights, might be heavy, assuming to be 700 pounds or 317kg)
- "only a sixth of its length was subject to friction", a possible indication that only a small portion of the length of the bearing is in contact to the support,
- plus small diameter, the friction between the bearing and the support is kept to its minimum, more efficient
- but in doing so, introduce the bearing to heavy tension a.k.a wear and tear (this is a double-edge sword situation, gain one, loss one)
- refer to image for information
- so, the question is ... why choose 'minimum friction (better efficiency)' running the risk of 'heavy wear and tear (short life-span or easy breakdown)' ?
