CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
b-XXV. trying my hands on wm2d, backward swinging method
- 2 methods for the swinging weights to swing backward
lumen
helloha,
I was attempting to apply the roberval action in the same manner as my working magnet motor simulation and it looks like it will work with gravity also.
To make it work you can simply flip the links using the roberval action at the top and bottom of the wheel ONLY.
This allows you to use a balanced system to flip the weights at a point where gravity is effecting the weights the least.
helloha
b-XXVI. trying my hands on wm2d, Roberval Balance vs See-Saw Balance v38 (fletcher + lumen version)
- testing on the backward swing method, but not a success
helloha
b-XXVII. trying my hands on wm2d, Roberval Balance vs See-Saw Balance v39
- simple test on swinging weight affecting on the roberval gear
helloha
b-XXVIII. trying my hands on wm2d, Roberval Balance vs See-Saw Balance v40
- simple test on the interaction between the rolling weight and swinging weight, which in turn, affecting the wheel
