marathonman
HANON;
"Another advantage is that inside the induced electromagnets we can put
another small size induced electromagnet with equal or greater length than the
large induced core. In these second group of induced coils an electric current will be
produced, as in the first group of induced coils, and this produced current will be sufficient
for the consumption in the continuous excitation of the machine, being completely free
all the other current produced by the first induced electromagnets in order to use it in all
purposes you want."
Could it quite possible that this is what he is talking about. (In these second group of induced coils)
Doug1
Marathonman
  I cant get the E core to model up at all to work with the idea of having the same inducer fields pushing the induced to behave like a rotating magnetic field. The collapse time on the inducer fields would have to go completely off and allow the field to dissipate to zero.That would not work with the idea of having the the magnet going up in field strength pushing the collapse magnet back emf around to add to the one increasing. It also doesn't even allow for the notion of keeping the cores partially on to maintain a pressure between the fields even after correcting the pole orientations of the inducers. If you get an LED to run of it you should consider yourself doing well. The flux will want to travel around the outside of the core if you orient it nsnsns and totally avoid the center leg of the core and if put it in nnnsss there wont be any difference in flux in the middle as each side turns off or on. If it was a square then maybe if it is not too leaky. Use bobbins just in case it turns out Im right. So your dont  risking wasting your wire.
Doug1
I dont like the picture thing but I guess ya gotta do what ya gotta do.
Doug1
Doug1
