0 Members and 70 Guests are viewing this topic.
hanon
Hi all,
As bajac has his upload capacity full I have attached here his document about the interpretation of Figuera´s 1902 patent  (No. 30378 - Generator Figuera-Blasberg )
The attached file belongs to bajac. I am just uploading it.
iflewmyown
Quote from: bajac on June 24, 2013, 08:05:39 AM
@iflewmyown,
After reviewing your setup, I see the following issues with your setup; first, the center iron core should no have voids. It should be a solid uniform piece. Second, you need to make the gaps uniforms. The interior and exterior iron core pieces should be firmly attached. Third, I am not sure about using welding. You may be better off attaching the different parts with screws. Fourth, use rectangular interior iron cores. A round shape makes it more difficult to wind the Induced coil.
You can use laminated sheets to build the iron cores. For example, I have Silicone Steel sheets from an old 45KVA transformer. I can cut enough pieces with scissors to form the exterior and interior cores.
My recommendation to you is to start all over again. I keep saying not to cut corners when replicating the device. If you can afford it, make the drawings with dimensions and bring it to a machine shop for a good finished product.
Bajac
Bajac, thanks for your comments. The center core has more iron mass than the coil cores and should not be an impediment to the flux.
If you look at the second picture you see that the gaps are adjustable with the spacers behind the exterior magnets so that after any induced winding is placed in the gap the gap may be closed tight.
The octagon has machined ends and was shrink welded and checked for gaps.
Clemente and Robert Adams both found lamination unnecessary.
I was attempting to build a working device with enough output to be undeniable. Many small devices produce so little output that they are impossible to measure with accuracy.
Thanks,
Garry
bajac
iflewmyown,
Where is the induced winding? The turns of the induced winding should pass through the air gaps in accordance with the 1902 patent.
Bajac
iflewmyown
Bajac, I tried many induced winding patterns months ago, except your fig. 8. The device had been dismantled and stored. I have many devices and limited bench space. When I saw your post I set the unit back up again and ran tests on that configuration. It was stored again by the time you wanted pictures.
I am now building a device with laminations for further testing.
Thanks
Garry
Doug1
A gramme wound seconday two oposing core two primary single ignition coil  potentailly ballanced against the source voltage. Shared cores on a single frame wont make it easier to build. Gramme winds to secure desired voltage/amperage, combined units to secure more amperage.Secondary and primary connected.The question is how and where and is the secondary a floating ground.
