0 Members and 45 Guests are viewing this topic.
Cadman
Ever wonder what that other little wheel was for at the left of the Figuera commutator in the patent drawings?
Hexabyte
deciphered for ease of reasing.......
Dated: June 9th 1907
Uses Electricity Without A Medium:
Scientist Declares He Can Apply Atmospheric Current Without Motive Force
Was – Simple – Discovery
Senor Clemente Figueras, Engineer, of Canary Isles, Inventor of Method
(Special Cable To The Herald)
The Herald's European edition publishes the following from its correspondent: -- London, Monday. – A most remarkable claim, the genuineness of which it is as yet impossible to test, says a cable dispatch published by the daily mail from its Las Palmas correspondent, has been made by Senor Clemente Figureras, Engineer of Woods and Forests in the Canary Islands. For many years professor of physics at St. Augustine's College Las Palmas.
It seems that for many years he has been working silently at a method of directly utilizing atmospheric electricity – that is to say, without chemicals or dynamos – and making a practical application of it without the need of employing motive force.
A true revelation might rob him of his reward and even now, while he claims to have succeeded, he is silent concerning the exact principles of his discovery.
He asserts, however, he has invented a generator by which he can collect electric fluid so as to be able to store it and apply it for infinite purposes – for instance, in connection with shops, railways and manufacturers.
He says he expects its effect will be a tremendous economic  and industrial revolution. He will not give the key to the invention; but declares that the only extraordinary point about it is that it has taken so long to discover a simple scientific fact.
He intends shortly going to Madrid and Berlin to patent his inventions.
In addition to the discovery, the Daily Mail says that, according to letters received in London from his friends in Teneriffe, Senor Figueras has constructed a rough apparatus by which, in spite of its small size and defects, he obtains a current of 350 volts, which he utilizes in his own house for lighting purposes and driving a motor of twenty horse power.
His inventions comprise a generator, a motor and a sort of governor or regulator. The whole apparatus being so simple that a child could work it.
Fernandez
Attached is one of our preliminary circuits we devised. Its actually based on the study of Joseph Henry. We figured that Figuera lived in the era of Faraday and Henry. So logic would dictate that the answer would be found in one of there works.
This is a simple circuit that's EZ to build. Do what you want we are just presenting a starting point. Because we ALL know that STARTING is the hardest part. To understand the circuit (some of you will already know whats going on here) research the works of Joseph Henry. Add to the circuit as you wish. The goal is to reduce the input  current to achieve the greatest magnetic force possible (just as Henry did, its all documented over 100 years ago).
Criticize all you want, clearly theirs something we all all overlooked because its been over 100 years since Figuera. For starting, try winding 1:1 ratio's on the transformers (air core). The output transformer requires Iron. I have already disclosed a cheap usable source, do not waste your money on high end iron its simply retarded.
We believe the Georgian fellow uses the same technique as Figuera. We also believe that Henry stumbled  upon an interesting magnetic effect. However Faraday published his works first and Henrys work got buried by history thus falling by the waste side.
A starting circuit:
forest
Hmm..."atmospheric electricity", "aether"......it was used to fool people.  Only a few inventors said clearly , and it was Hendershot,Perrigo and Steven Mark. Read them and you will find the real truth which is crushing. For over 100 years we are paying for nothing....
Doug1
Fernandez
  Your pdf is a simplified version of patent 3815030 Square wave driven power amplifier Dated June 1874 owned by Westinghouse Electric company.
  Without the details of how to feed the output back into the inducers with the advantage of gain or leverage to increase the output while using less current and not burning up the inducers when loads are varied there is little chance of getting any design to self run. Even the patent mentioned does not go into or even mention the ability to do so in detail or concept. Only figurea gives mention to it being equal and suppressing the source which could then be removed. If that was known then it alone could dictate how to hack any device to operate off it self.
