0 Members and 53 Guests are viewing this topic.
hanon
Quote from: Doug1 on October 20, 2014, 12:30:11 PM
If I were to take a guess it would be that your six months away from resolving the major problems. If you focus too much on design and not enough on operating principle you will miss the method to close the loop.
  Yea I said close the loop. The point where a little is fed back and acts like a lot.
If you want some light reading try Archimedes from 300 B.C.
Doug, I can not understand your post
Quote from: antijon on October 20, 2014, 12:32:11 PM
Bajac, thanks for the pdf, though I can't read it until I get home.
Hanon, it's interesting that you say that. There's a brilliant guy on YouTube that I started following. He made a transformer setup here- http://youtu.be/iGzR0NJ4vRE and though I didn't really understand, he does mention two secondary coils of opposite polarity.
Antijon, Thanks for the link. It is interesting. It seems to use two induced coils in order to compensate their effects.  I don´t know how it is configured.
I tried to understand your last video but it is too complicate for my level. I will try it again this night
antijon
No worries Hanon. I was just proving that in a Figuera setup, or other similar design, the flux of both inductors add together. So, if 12V was the source, the combined flux would equate to 24V of flux. Essentially, the induced coil would have double the voltage output.
Doug1
Well antijon congrats you found the secrete.
   How ever the object is not to just control the flux. If you treat each turn as an entity you can just as easily obtain the flux equal to 100 volts and thirty amps from only one volt and one amp. Or 120 volts at half an amp. It's leverage over the field by controlling the resistance in ever more taps on the coil. Let me squash the dumb arguments before they even start. A magnetic field of sufficient strength will appose the current in every way from opposing field of equal strength. As if the passage of current were being stopped with a great resistance or reluctance. Its more combination of the two. Now do you understand why I wanted to use parts from starters and alternators. I need big fat thick powerful inducers made from stuff that already has the values worked out.Anyone can wind an output coil but those beastly stators are made from conductors that don't cooperate. It's like trying to bend a nail around another nail. A 5 kw starter has 2 sets of 2 coils that handle 5 kw.
   The taps can be used singularly or in groups. Obviously if you go off the patent you view the seven N and seven S as taps connected to layers. If he had seven turns or seven layers the only difference would be the input voltage and amperage. How ever in your quest you need to find the smoking gun. The tap he used to close the loop. The input must equal the portion of the output to be used to self run. That may mean you have to use multiple taps, depends on how you build it. Ya know that old saying keep one hand in your back pocket when your handling electric. This would be one of those times you should adhere to simple safety rules. The more it draws the more it makes because it opposes the change. The state of equilibrium will be maintained even if it has to turn you into a burnt french fry to do it.
    Im glad I cant be blamed for the destruction of the global economy all by myself.
hanon
Doug,
Your dense text is difficult to follow for those as me with a mother language different to english. Besides of having good ideas it is also important to be a good teacher, and simplify things. Also it is imporant to have in mind that Figuera will help to avoid 2.8 million people dying of starvation each year, as happens nowadays. I always have that in mind in each post I write. We have to learnt to share the things we have in our wealthy world. They also deserve to have it. As Tesla said energy is the key for development.
About closing the loop I think it is not so important at this stage. Just a simple device (and simple to build) will be more than enough to start falling the dominoes pieces.
ovaroncito
Quote from: antijon on October 20, 2014, 01:04:11 PM
If the source is 12 V, the commutator is splitting the 12V in two parts for the two inductor coils (which add up to 12V). How can the combined flux add up to 24V? Is there an explanation?
