0 Members and 88 Guests are viewing this topic.
bajac
I consider the air gaps the most important feature of the Figuera's devices. It is against the common sense used in today's electric machines. For example, the discontinuities of the iron cores represented by the air gaps is to be avoided at all cost in today's standard transformers. Nevertheless, the discontinuity of the air gaps is what makes Figuera's devices work. The air gaps must be minimum, but they must exist. These air gaps create a reluctance circuit that allows the magnetic flux to be manipulated with ease for the purpose of minimizing the effects of the Lenz's law.
The above statement implies that the quality of the iron material is not critical. The reluctance of the small air gaps is thousands of times larger than the reluctance of any low quality iron core. The latter is also the reason why the design criteria of the Figuera's apparatus is based around the air gaps.
No considerable amount of power can be obtained without the air gaps feature. If you don't believe me, ask Thane and the BiTT transformer.
Bajac
Liberty
Quote from: bajac on July 05, 2013, 08:48:34 PM
Bajac
Anyone able to make one self run?
Liberty
Doug1
It's been non stop rain here for days which has put a real damper getting much done.So I spent time pulling apart a 10kw inverter that failed to see why before gutting it for parts. As I was examining the transformers all 16 of them I decided to take one totally apart. They are EDT-39's ,much to my surprise they'er not wound with wire they use copper tape windings.Vastly easier to wind or rewind. The tape fills the bobin width and turns are layered. A funny thing though they are wound a bit like the Figuera's device with two differences. They use a single core made from a split core,two E cores really..The coils are layed on top of each other. As if the first is a primary ,second the induced secondary, then another primary over that.The induced secondary is center tap while the primaries are not, just to be clear. Im pretty sure that is to do with it putting out ac and to increase the self inductance of the coil. The cores are made of very nice material ferrite. It would be very easy to cut the tape in thirds width and add an air gap but there is no complete discription of how the Figuera's device is wound or if he used center tap winding on the induced. Maybe someone can find out when the center tap idea came about in history. Such as who discovered it and when. I know the inverter tech works and allways wondered how those little transformers could handle such large currents now I know. They use copper tape not wire. The insulator is just a slightly wider piece of thin plastic sheet. The tape is not coated nor bonded to the plastic insulator.Copper tape is short only a couple of feet each winding,very easy to work with very fast.I never would have considered tape before this now I may never again use wire the labor difference is too great to overlook. It would very funny if an DC to AC inverter is only a couple of tweeks away from being the finish product. I imagine there will be more pissed off people then can be counted.
Doug1
I decided to take a closer look at how these transformers are connected to the cuircuit board becuase something just didnt look right in the solder on the board.Some of the pin holes apeared to to clean ,virgin. I kept placing one transformer back in it's place and realized two pins were missing ,cipped off.In fact the same two pins on each of the 16 transformers are  nipped off at the ends so it doesnt reach the holes on the board.The outer most winding is only connected to the board from one end of the winding but made to look like it is connected at both. It would be easy to miss unless you noticed the defect is the same on all of them. Thats pretty strange.
RMatt
I blieve in the quest of the true hearted explorers, and laugh at the non-believers. this that I do has been done for centuries. the only thing that needs to be overcome is the BIG BANKS, THE Government THAT HAS BEEN BOUGHt<NOW MY COMPUTER WILL NOT WORK RIGHT FOR THE FIRST TIME>
