0 Members and 40 Guests are viewing this topic.
ignacio
"La sobre unidad de la maquina", ¿¿¿¿ por –inducción de (inductancia, reactancia) resonante del bobinado????, así se entiende, hacer las bobinas colectoras idénticas, lo mismo con los electroimanes, cuando una cuerda entra en resonancia con otras vibran todas a la vez, Parece ser lo que se explica en la página HYIQ, me vale como respuesta a la sobre unidad
"The overunity on the machine," ¿¿¿¿ the induction of (inductance, reactance) resonant winding ?????, well understood, there are to do collecting coils  identical , same with the electromagnets.
when a string resonates with other vibrating all the time.
Seems to be what is described on page HYIQ, I better response to the overunity of the machine Clemente Figuera
bajac
Presently, only a person has sent me a PM telling about his experience with the books. It looks like the book was not what he was waiting for.
Thanks a lot to this person.
@ Ignacio,
Could you, please, post photos, diagrams, videos, etc., of the equipment you are referring to? I am afraid that most of us do not understand your concept.
Thanks for participating.
Ignacio,
Podria usted, por favor, publicar fotos, diagramas, o videos, etc., de el equipo a que se esta refiriendo? Me temo que la mayoria de nosotros no entendemos su concepto.
Gracias por participar,
Bajac
bajac
This post is needed for clarification. As you already might know, my second prototype of the 1908 device was more disappointed than the first one. I hinted that my previous belief that the iron core would never saturate might not be correct. Well, today I am certain that the iron core will follow the iron saturation curve, which makes my second prototype a failure because I used a smaller iron core than the first one.
I am attaching a graph of a document I found in the internet showing how the iron core of the electromagnets saturates. I will eventually build a second prototype with much larger iron core but first I will test what I have for saturation. The test will consist on applying an AC voltage to the primaries, one at a time, and check for the voltage waveform induced in the secondary (centre) coil. When saturation appears, the induced voltage should flatten at the top.
Like someone once said, it is just another way of not building the device. This time, I will not make the same mistake as with the first prototype, I will not dismantle it.
Thanks.
ignacio
Parece que hablamos idiomas diferentes.
   El que diga yo, que los de hyiq.org den una alternativa al funcionamiento de la maquina, no es otra cosa, que, el funcionamiento tiene algo que ver, con lo que he leído en internet, del funcionamiento de los tubos fluorescentes, la función de la reactancia y el cebador, (¿una reactancia funciona igual que 7 reactancias?). Es la alternativa que más me ha convencido.
   En cuanto a la onda de alimentación, con el video de ixfes está aclarado, es una onda sinusoidal pura, que reproduce el cachivache (en aquella época empezaba la corriente alterna). Si la ca son dos cables, cuando uno está en 1 el otro está en 0, si uso uno ¿tengo la mitad de siclos?¿tendré que usar 50hz100 o 60hz120)? Que tenga que jugar con los siclos, ya que se alimenta con una parte del siclo, es otra cosa. (casi todos los aparatos que me han dejado o fabricado, los he quemado o roto (creo que por los retornos, chapuzas)
   Que si son polos enfrentados o no, no tengo ni idea, cada vez que hago pruebas, cambio los cables según de más o menos corriente, ya os digo, que no tengo ni idea de electricidad (para el chicharrero, soy un tenique o velillo = piedra o roca, tronco), no me planteo la polaridad de los-as bobinas y electroimanes.
   Por lo visto hay algunos que esto lo tienen como trabajo, (trabajo = dinero o contraprestación), "el jugar" la única contraprestación es el entretenimiento y "conocimiento", así a los que lo tengan como trabajo, va siendo hora de que se pongan a trabajar y tengan una contraprestación razonable (unos cuantos millones como mínimo, no una miserable limosna) no ha esperar que otros le den soluciones (parecen políticos).  esto les dará una idea a los que nos gusta jugar con estos cachivaches.
It seems that we speak different languages.
-- I say who hyiq.org they give an alternative to the function of the machine, the operation has something to do with what I read on internet, the operation of fluorescent tubes, reactance function and primer, (!1 reactance works equal to 7?!). It is the alternative that has convinced me.
-- Power wave with video ixfes (cacharreo) it is clarified, is an pure sine wave, which produces the gadget (antique, started alternating current). If ac are two cables, when one cable is in 1 the other is 0, if I use one cable do I have half shekel will I have to use, 50hz-- 100 or 60hz--120? Have to play with the shekels, and if it feeds a part of a shekel, is another thing. (almost all devices that have left me or manufactured, I've burned or broken (I think, for the returns ac, bungling)
-- What if they are confronted the poles?, I have no idea, every time I tested, It change the cables, when of more or less electric, and I say, I have no idea of electricity (for chicharrero, I'm a Tenique or velillo = stone or rock),  coils and electromagnets I don't consider the polarity, to tested.
-- Apparently there are some that this will be it as work (work = money or consideration), "to play" the only consideration is the entertainment and "knowledge". To those who have it as work, it is time to be put to work and have a reasonable consideration (at least a few million, not  alms misera) must not expect to others, to give solutions (political speak).
This he will give them an idea to play with these gadgets. I hope, does not you does pictures or video lack
--- only resistive drive was patentable in the time of Clement Figuera, the rest could not be patented because it is free energy.
hanon
Well,
There is a thread showing a running generator with no back emf, surely based on the same principles as the Figuera patent with the rotary coil, patent #30376 . Please reviw this link:
http://www.overunity.com/15083/the-new-generator-no-effect-counter-b-emf-part-2-selfrunning/
http://www.overunity.com/15088/new-generator-no-effect-lenzlaw-give-more-detail-in-pcture/
It has some interior static magnets, and instead of rotating the coil, as Figuera did, this design rotates a soft iron plate around the interior magnets
