0 Members and 27 Guests are viewing this topic.
hanon
Hi all,
As maybe you know there are two parellels forums about Clemente Figuera, one is this one, and the other is at energeticforum dot com. There is a question in energeticforum about the formulation of the Law of Induction. One formulation states that the magnetic lines  (B field) must cut perpendiculary to the moving wire (at speed "v")  of length "l" to produce induction E = (v x B) · l ·sin(alpha) , while the other formualtion E = - N·A·(dB/dt)  is related to the area A of the coil and no "cutting" of wire is needed to produce induction.
For those interested:  an interesting fact about the Induction Law here I link a file which explains that two different formulations seem to exist for the same phenomenon : one,  the Faraday Unipolar generator: E = (v · B) , other the Maxwell 2nd Law :   rot E = -dB/dt, which are two different formulations for the same law !!! Faraday-or-Maxwell by Meyl (read page 5 and next of the file). Meyl proposes a theory to take into account the longitudinal waves which were predicted by Tesla in his wireless power transmission system.
An interesting point which Eric Dollard comments in an old presentation  (Youtube video ) is that in the secondary of transformers the induced current is produced  in the wiring WITHOUT being cut by the magnetic field. Most of the magnetism is supposed to be enclosed into the iron magnetic circuit and therefore no magnetism should cut the secondary winding, which is external to the iron and only encircles the iron. Can anyone explain it to me???
Please comment if you see any inconsistency or error in my sketch. Maybe we are trying to explain it with the equation E = v·B·l·sin(alpha) ,and we should look for any other equation which fits better this phenomenon.
Another doubt that I have is why this equation does not work by approacing o moving away a single conductor from a magnet, while the common Faraday equation E = N·A·(dB/dt) works perfectly with a coil approaching or moving away from a magnet.  Why the area (A) is included into this equation if the central lines of forces (inside the area) do not "touch" the surrounding conductor?? For me it would make more sense to use the perimeter instead the area, don´t you?.... I think we still have some misteries to solve around Magnetism !!!
hanon
I have found this patent US20020125774 which has some features in common with one of Figuera´s patents: Link
In fact they both have different wiring disposition but it can be one other implementation of the motionless generator described into patent No. 30378
PS. Also a curious video I have seen: TPU Secret - Steven Mark
hanon
"No single solution will defuse more of the Energy-Climate Era's problems at once than the invention of a source of single solution on abundant, clean, reliable, and cheap electrons. Give me abundant, clean, reliable, and cheap electrons, and I will give you a world that can continue to grow without triggering unmanageable climate change. Give me abundant clean, reliable, and cheap electrons, and I will give you water in the desert from a deep generator-powered well. Give me abundant clean, reliable, and cheap electrons, and I will put every petrodictator out of business. Give me abundant clean, reliable, and cheap electrons, and I will end deforestation from communities desperate for fuel and I will eliminate any reason to drill in Mother Nature's environmental cathedrals. Give me abundant clean, reliable, and cheap electrons, and I will enable millions of the earth's poor to get connected, to refrigerate their medicines, to educate their women, and to light up their nights."
Thomas Friedman in "Hot, Flat, and Crowded" 2008
hanon
bajac
John,
There is a very important aspect to be aware of when designing the 1902's device. The effective wire length, in which voltage is induced, is equal to the distance of the iron core's depth. In other words, a turn of wire crosses the air gaps twice in the direction of the depth of the iron core inducing two times the voltage. I noticed that the depth of the iron core shown by iflewmyown looks small. I thought you might want to take the latter into consideration.
Hanon,
Thank you very much for your incredible contribution!!!
Bajac  [/font]
