Doug1
Here is a better perspective of the circular thing I refer to as the commutator and of the version which uses split brushes. Maybe it will help you to wrap your head around it easier.
Doug1
 Now what of this crazy thing. How could you utilize it as it is drawn?
It may be assumed that all these lines connected the two together actually exist all at the same time. Not so, the represent positions to connect to that move current a little more or a little less to either the N coil or the S coil. Why ever would you want to do that?
  Could it be that if you were drawing a portion from the alternating current and converting it to direct that in that case you will unbalance the wave form of the alternating current?
   If that is the case, which it is.That should lead to you to figure out how he is rectifying the output so as to limit the alternating current being used to excite the inducers that came off the output before it enters at the same inputs as did the battery which started it. Another clue is the current from the battery will be equal to the current from the part or method to rectify the output.
Doug1
Ignacio
How do you adjust the current going to the inducers to re balance or compinsate for the rectified feed being used to replace the battery as a source? Both the working load and the power back in dc are off the output.
  You picture of the truck with the magnet pulling itself? How much $$$ do you want to spend to make one?
