ignacio
Quote from: Doug1 on December 01, 2014, 10:26:23 PM
Ignacio
How do you adjust the current going to the inducers to re balance or compinsate for the rectified feed being used to replace the battery as a source? Both the working load and the power back in dc are off the output.
  You picture of the truck with the magnet pulling itself? How much $$$ do you want to spend to make one?
¿Cómo rectificas la corriente de alimentación en los alternadores de los coches?
Estas imágenes me gustan. Je je  je
How can you rectify feed stream the  alternators in cars?
These images I like. Heh je je je
Doug1
Yes but the 6 diodes in an automotive alternator waste a lot to heat thats why the diodes are mounted to heat sinks and the alternator has a fan on the front. Even with that if the regulator over powers the field winding the diodes will cook and fail.
  I like your drawing to.
hanon
I have found a reference to the induced coil orientation in the Buforn´s patent No. 47706 (year 1910), the first of the 5 patents that Buforn filed copying Figuera´s 1908 patent. It is the only reference to the induced coil placement I could find in those patents.
"Our invention is also based on that other reasoning "If several spirals or loops are placed within a magnetic field in the plane of the magnetic meridian, from the time they start to rotate a current with weak voltage will appear, and those voltages will add up when the loops are placed one after the other."
Note that Buforn is referering to "the plane of the magnetic meridian". I suppose that the meridian is the line which joins both poles (as the geographical meridians join the Earth Poles).
It seems to suggest that the induce coil is placed perpendiculary to the electromagnets.
Could it be possible? What do you think of this?
marathonman
Hanon,
very good detective work i might add. it seems that Mr Buforn spills the beans more than we knew.
it also states that they do not need to be separated in any way like a III situation. the flux will transfer or rather be attracted to the iron core next to it. maybe they are just straight cores placed next to each other and the week sum of all cores add up to the total that one needs for his or her application .
marathonman
Hanon,
Look at this for some info.
Not just earths field but any magnetic field.
