0 Members and 61 Guests are viewing this topic.
a.king21
If the winding is exactly as specified then several additional factors come into play:
Namely the interrupter and capacitor. They together with the coil form a "tank circuit".
Tank circuits have been known to produce reactive power in excess of input power.
Conventional theory holds that you cannot get this reactive power out, because to do so stops the
process that creates it.
I don't subscribe to this view.
RandyFL
Hello All,
a.King21,
So what you are stating is the Figuera is using a induction ( Ruhmkorff ) coil as a step up process...
I refer everyone back to what Whoopy produced:
https://www.youtube.com/watch?v=HlOGEnKpO-w
and what KehYo produced:
https://www.youtube.com/watch?v=hC70s3tYaGs
both on them produced results visually... when they took the secondary s out...the primaries were still functioning normally...
when I built my first 555 and 4017 circuit I used a low voltage 555 ( and forgot that I was using it ) and when I hooked it up to a 12 volt lawnmower battery the first thing I spotted was the spark from the battery...I thought that spark ruined the 555 ( it scared the crap out of me )...but the 555 was ruined because of being a low voltage 555...subsequently each time I use the lawnmower battery I get that spark...and now I just momentarily just tap the battery before using it...that spark is what fascinated Tesla into designing the ac motor ( or whatever He invented first ) that spark is the zero point energy field letting you know visually that its there...
Gentlemen/women...
I say go back and either build the rotary, the arduino or the circuit that Patrick designed and get the results that woopy or Kehyo got...
then increase the secondary windings...that spark is waiting for you.
Lastly...
when you look at the videos that woopy produced...look at the magnet wire He used and how many windings He turned...
when you look at Kehyo's video look at the resistor He used ... He states its a .01 ohm resistor
my point is... you have to have enough room on " your " transformer/s to allow at least 9 amps ( 12 volts ) to go thru the magnet wire...anything smaller isn't going to produce the " work " that you want. The resistors have to have at least 100 watt ratings...the power transistors and the resistors will get hot - maybe they could be used to heat up water or coffer but that's for another forum... :-)
All the best
RandyFL
Doug1
It's really hard to listen to woopy's videos.He sounds like one of those commercials on the spanish TV channels. Very dramatic sounding. Or the guy on the movie Bird Cage who cant wear shoes. Then I start picturing him singing "she works hard for the money" in the movie and my brain shuts down.
RandyFL
On a serious note...
I'm picturing 3 dancing bears on the Ed Sullivan show dancing to the tune " she works hard for the money"...
so in other words... Doug... you can't look at the video of poopy/woopy because of all the points in your last post... which I might remind you those are his good points lol...
Lastly...Patrick actually put His video on the website along with the data...and Kehyo actual repeated the results...
All the best
RandyFL
Here's another view of it with no one speaking...
The Figuera experiment:
https://www.youtube.com/watch?v=B2WCAA6st_s
The guy named Harry Hasler... produces a transformer with no gaps and then supplies the gap himself by scraping...technically you just need to insulate the primary, with tape, air maybe even bubble gum, away from the secondary...
My question is... Is Tesla's radiant energy part of the ZPE field or something different...and does a magnetic field dissipate into the ZPE field if it has no other place to go...as a magnet field doesn't disappear.
