Doug1
Im not knocking his work. Just saying it is hard to hear his voice and not be distracted by it.
a.king21
Quote from: RandyFL on May 17, 2015, 10:36:19 AM
Here's another view of it with no one speaking...
The Figuera experiment:
https://www.youtube.com/watch?v=B2WCAA6st_s
The guy named Harry Hasler... produces a transformer with no gaps and then supplies the gap himself by scraping...technically you just need to insulate the primary, with tape, air maybe even bubble gum, away from the secondary...
My question is... Is Tesla's radiant energy part of the ZPE field or something different...and does a magnetic field dissipate into the ZPE field if it has no other place to go...as a magnet field doesn't disappear.
This guy is nearer the mark. You need to understand interrupters, var, hf oscillations circuits produced by the tank circuit.  I am not into this configuration but feel that builders need to understand the principle. I believe  NRamaswami found a solid state way to produce the effect. I would really like to see NRamaswami's  scope shot and I'll bet it's full of spikes.
a.king21
patent from 30378  quote:
In the arrangement of the excitatory magnets and the induced, our generator
has some analogy with dynamos, but completely differs from them in that, not
requiring the use of motive power, is not a transforming apparatus. As much as
we take, as a starting point, the fundamental principle that supports the
construction of the Ruhmkorff induction coil, our generator is not a cluster of
these coils which differs completely. It has the advantage that the soft iron core
can be constructed with complete indifference of the induced circuit, allowing
the core to be a real group of electromagnets, like the exciters, and covered
with a proper wire in order that these electromagnets may develop the biggest
attractive force possible, without worrying at all about the conditions that the
induced wire must have for the voltage and amperage that is desired. In the
winding of this induced wire, within the magnetic fields, are followed the
requirements and practices known today in the construction of dynamos, and
we refrain from going into further detail, believing it unnecessary.
So Figuera gives some clues here as to the coil construction.  Obviously it's not a classic induction coil as it differs completely. But the basis is a Ruhmkorff coil.
Hilarious! Notice how he switches the meter from a Volts range to a Current range without changing the connections! This is the "Steve Spisak" method of measuring current: simply put your near-zero resistance Ammeter directly across the output terminals of your device, just like you would use a high impedance Voltmeter!
The "scraping" is producing an intermittent contact, turning on and turning off the current to the coil. The voltage induced in the "secondary" is proportional to the time rate of change of the magnetic field produced by the turning on and off of the current in the "primary". The sharper the cut-off, the higher the voltage induced. This is just ordinary induction at work, there is no need to invoke "ZPE" or any other hypothetical construct. Where does the magnetic field go when the current producing it cuts off? It goes back to the same place it came from: charge in motion. The moving charges created the magnetic field, and the collapsing field tries to keep the charges moving in the same direction, hence producing sparks and higher-voltage spikes.
Quote from: a.king21 on May 17, 2015, 07:18:13 PM
Here's a "solid state" way of producing ... wait, what effect are you talking about? Voltage amplification by rapidly collapsing magnetic fields, in a resonating tank circuit full of reactive power? Ok, we've got that covered:
http://www.youtube.com/watch?v=XeQ5WnziKBA
(30 VDC input at less than 2 amperes)
Sorry... I'm not about to connect my Ammeter _directly across_ that output ....    ;D
