0 Members and 99 Guests are viewing this topic.
hanon
Quote from: forest on August 23, 2013, 04:46:51 PM
Again : is there anything in patent text about box around the connection point from the commutator to power supply , I spotted ?
Maybe there is a better , bigger  picture of the method of connection here ?
Why ? You should easily guess.... ::)
The connection box has intiged me since I saw it. I domt know what represents and there is no further explanation in the text. It is only mentioned that the current after doing its task in the electromagnets returns to the origin where it was taken..
forest
Quote from: hanon on August 24, 2013, 03:27:55 PM
you see... origin ? not power supply ???  ::)
better give us the complete translation
RMatt
Hi all,
In Reply #199 it was mentioned about 3 phase line reactors on ebay. I just purchased 10 of the transformers for a total price of $173.23. Expensive, but I hope they will work. I should recieve them by 29 Aug 13.
Bob
bajac
I also bought 10 line reactors of about 3/4HP. I am still waiting for them. Something to keep in mind is that the line reactors are designed for 3% impedance only. Which means that there are not too many turns in the coils. I had recommended about 300 to 400 turns for the N and S coils. The wire gauge of these electromagnets can be AWG#18. The "y" electromagnets shall not be less than 200 turns and no smaller than AWG#14.
You need to be careful when cutting the iron core. The laminated core should be pressed or sandwiched between two pieces of stiff material to avoid damaging the steel sheets.
RMatt
bajac,
The ones I bought were RL-00201 reactors, 600V 2Amp. I thought they might need to be rewired, but did not know wire size and turns. Thank you for the information.
Bob
