antijon
Actually MagnaProp, I enjoyed the excerpt. Ed was right, too, as that's how lifting magnets are made now.
I don't know what you guys are talking about with the Lenz... Lenz current is the reason why a transformer can be plugged in with nothing on the secondary. It's what we call the impedance, or inductive reactance. It's also what lets an induction motor pull such low current.
We all know that motors have very low ohms, right? Most compressor motors I see have about 2 Ohms, which at 240V would draw 120 amps. But because of the Lenz law they only draw about 8-12 amps depending on load.
Figuera's generator uses Lenz to aid it, just like an AC motor. That's why it has to be a North and a South. See, because of his commutator, when one is increasing in strength, it produces a back voltage, or Lenz current, in the other. this effectively nullifies a part of the incoming current, so instead of a high current it would only need something small to run.
That's why woopyjump's video is a perfect demo. The north and south have to be inductively coupled to lower the current draw. And I don't know the guy, but I wonder if he made a larger setup. I think large inductors would show a much larger effect, like extreme power out with little current in.
hanon... "or either, being close the induced
and inducer and in contact by their poles"
doesn't this mean that the inductors are aligned and their poles are in contact? Parallel inductors, right?
marathonman
So can someone please tell me where it say's that the inducers are C cores....... yah right!  that's what i thought.....NILL.
that's why everyone using c cores got squat output and will continue to get squat output.
that's why i chucked the C core design cause it don't work.
antijon sorry its not a Gramme ring.
marathonman
antijon{quote{@ marathonman, I know your coil setup imitates a rotating generator, particulary the Gramme ring, which we all know is the father of the "barrel winding" motor or generator... but I really don't think you'll have much success. I know hanon and I have both experimented with transverse or perpendicular windings with little output. You probably will get some output because of the North and South coil orientation, but not a free energy machine. Barrel windings literally cut the magnetic field lines, that's how the current is excited, so without moving the coil or magnet you're just relying on induction, which isn't very much in this case.
Quote from Figueras Patent....Thus, varying the intensity of the current, varies the magnetic field which crosses through the induction circuit.
Quote from Figueras patent...Therefore it does not matter if these induced currents were generated by rotating
the induction coils, or by varying the magnetic flux which passes through them.
Quote from Figueras Patent...The principle on which this theory is based, has the unavoidable need for the movement of either the induction
circuit or the magnetic circuit, and so, these machines are considered to be a transformer of mechanical work into
electricity.
Quote from Figueras Patent...In order to attain the production of large industrial electrical currents, using the principle that electrical current can
be provided by just changing the flow of magnetic flux through an induction circuit.
Quote fron Figueras Patent...DESCRIPTION OF GENERATOR OF VARIABLE EXCITATION "FIGUERA"
The machine is comprised of a fixed inductor circuit, consisting of several electromagnets with soft iron cores
enhancing induction in the induction circuit.
NOW ! what was that you said about induction antion. next time read it twice.
RandyFL
Hello All,
Welcome back MarathonMan...
I have been busy with Life projects ( wall oven, cooktop, range hood and wall bed ) and last but not least surgical procedures... My morning studies have taken me in a different direction. The automobile alternator is the most important apparatus in a ICE and is the backbone of the Tesla electric Automobile  ( only bigger of course ). My point in this is... Tesla has/had a patent on motors and generators...the difference between a dynamo and a alternator besides the spelling is the dynamo is dc and the alternator is ac ( sorry for being redundant here - I'm sure you know all of this ) anyway... Nikola Tesla already figured out the synchronicity of a motor and a alternator to be used to for work  ... hence you power up the electric motor ( with whatever means you want ) which turns the alternator which produces the electricity to run the motor = synchronicity = Ockham's razor. The rocket scientists have already used bemf s to detect where in the cycle of 3 phased bldc motors to their ( ours too ) advantage...
the difference between Doug1 and my outlook on greedy corporations is if you want to beat them invest in them... its called a dividend. We probably agree on the One World Order which is for another thread elsewhere.
Lastly...I agree with your work ( its simple and very logical ) so build it.
welcome back
All the best
RandFL
Doug1
