0 Members and 97 Guests are viewing this topic.
ariovaldo
Quote from: bajac on September 19, 2013, 09:49:49 PM
Hi all,
I have to say that I am very happy to see the enthusiasm and effort shown by the members of this forum about Figuera's devices. Figuera's technology is free and it is here for the taking.
First of all, I apologize for not being able to provide the detailed description in a single document of the device that I am building. I have been really busy with other affairs that do not allow to spend time on this project. However, all information about Figuera's technology has been disclosed in this thread.
The main components are the iron cores and the windings. For example, the key components of the 1908 device are the electromagnets. Once you build the electromagnets, you only need two 90-degree shifted full wave rectified voltages. It does not matter how these input voltages are generated! If you do not know how to build the electronic circuits, you can use the commutated switch and the power resistors shown in the original patent. For the size of the device shown in this thread, it is recommended that the power resistors have a minimum rating of 50W and a maximum of 10 ohms. THESE RESISTORS GET REALLY HOT! That is why Figuera showed wire wound resistor type. When Figuera ran his tests, I can imaging these resistors getting red hot similar to wired heaters. The use of these resistors is the least efficient option. The resistors dissipate relatively high energy.
A better option for generating the input voltages mentioned above is to use a motor-generator. The generator should be able to provide two sinusoidal voltages shifted 90 degrees. Then, each of these generator AC voltages can be applied two a full-wave rectifier diodes.
If the iron core is big enough to house the coils, you can use about any iron core that you feel comfortable working with. The cross section of the iron core that I used is about 1 inch width and 3/4" depth.
I have also recommended to build the 'N' and 'S' electromagnets with no less than 300 turns with a taps, let's say 200T, 300T, and so on. If you can do 400T, it is even better. The minimum gauge size for these primaries coils should be #18 AWG.
I also recommended that the wire of 'y' secondary coils should have a minimum gauge of #14 AWG. Minimum number of turns should be 200T. The use of #14 AWG wire for the secondary will allow for the connections of heavier loads.
The other important design criterion to keep in mind is to minimize the air gaps. If you refer to the photos I posted a while ago, you will notice that the air gaps consist of a paper thin insulator.
The above recommendations are based on my own experience with this device. If you follow them, you will have a device with good power output during testing.
With respect to the 1902 patent, the primary coils should have a lot of turns. For testing purposes, I would use no less than 500 turns of #20 or #22 AWG for each of the primary coils 'a' and 'b'. Because the secondary must travel through the air gaps, the air gaps shown in the 1902 patent are considerably larger than the air gaps of the 1902 patent, and therefore, the magnetic reluctance of the of the iron core is much higher for the 1902 device. The latter implies that to create a considerable magnetic flux in the 1902 device, you will need a very high A-T (Ampere-Turns). And, that is why Mr. Figuera furnished the air gaps of the 1902 device with primary coils 'a' and 'b' located on both sides of the air gaps.
Thanks again.
Bajac
Sorry if I didn't do my homework, but I have some questions: the iron core: is it laminated? When you say " 2 times 90 degrees voltage" what exactly you mean? I' m building one oscilator using the patent principle. This device will generate a complete ac sequence.
Thanks e sorry about the dumb questions.
bajac
ariovaldo,
Based on your questions, I have to assumed that you have not read the paper that originated this thread explaining the operations of the 1908 and 1902 devices. For the 1908 device, please, use the latest revision posted on this thread. I highly recommend you to read these papers and whatever was posted in this thread before building your device. There are a lot of usefull information.
My understanding is that oscillators devices are usually used for signal (very low power) applications. The input power for the Figuera's devices is relatively high. For instance, the 1908 device that I built using the power resistors required an input power of about 60 Watts. When I tested it without the resistors, the input power was about 15W. And, I am referring to the device with one set of coils only (not seven as shown in the 1908 patent) for which I posted few photos. Therefore, you need to make sure that whatever oscillator you are using is capable of handling that kind of power.
Thanks,
Bajac
ariovaldo
Some pictures from the electromechanic "inverter" that I'm building to test the patent.
The most difficult part will be the transformer.
Later on I will post the schematic and the resistors values that I will use to test this in one 3 phases 25 kVA transformer.
I'm not expecting any "OU". I want to learn and understand the circuit behavior ( I will take some scope shots)
Cheers
Ari
ariovaldo
Quote from: bajac on September 20, 2013, 07:54:55 AM
ariovaldo,
Thanks,
Bajac
Thanks.
The oscillator will be able to hand the power. The resistors will have the following values
Ohms     Volts
8       =  1
6.6    =  3.6
3.3    =  7.2
2.2    = 10.8
1.65  =14.4
1.32  = 18
1.1    = 21.6
0       = 24
What do You think?
bajac
Ariovaldo,
WOW! That is not an oscillator but a heavy duty commutated switch. You got some skills!
I wanted to ask you, how did you get the values shown on the voltage column?
Going back to the iron core application, Mr. Figuera stated in his 1908 patent that it can be of a low quality soft iron type. He also stated that a solid piece (not laminated) of iron can be used. His statement can be justified by the use of air gaps in the device. Because the air gaps have much higher reluctance than any low quality iron core, there is no noticeable difference in performance when using, whether high quality laminated Silicone steel sheets or low cost soft iron bars.
Thanks,
Bajac
