0 Members and 25 Guests are viewing this topic.
marathonman
Figueras used the the 1st to induce { increasing} while the 2nd {decreasing} as the Lenz effect supports the first increasing fields {same Direction}  therefore nullifying the lenz in the first. so basically Figueras is using it's BEMF or Lenz's effect  to aide his device in producing energy.so the only way the poles can aide each other and not interact with each other is NYN, SYS or NYN, NYN. in patent 1914 it states that it can be put one after each other so i am going with NYN, SYS, NYN, SYS ect......
actually Figueras is using 180 degree wave forms, as set S is zero the other set N is high and vise,verse. see pic below to see what i mean. by using this style of switching the coils will NEVER reach zero....ie switched after High to Low/Low to High point acting as a battery then series to raise the voltage.
as for the magnet placement Richard Willis is using a ringing effect in his device  as Figueras is not and it even states so in his Patent that there fore need no spaces or gaps between them. Figueras is trying to get the Highest flux possible {induction} from his device so a gap here is detrimental. just remember the square of the distance when dealing with induction.
Nicola Tesla and many others basically proved that their is a median that is so small that we can not measure it and that it permeates everything, basically it is the space between spaces. a mater of fact Dmitri Mendeleev, who came up with the periodic table of elements said there are elements lighter that helium that he cant measure but he knows it's there.
It's all about spin direction, our whole Universe is all about spin direction,  right hand spin/left hand spin, attraction/repulsion, convergence/divergence, space/ counter space   ect... Ken wheeler is a good start and is a  F-in very smart person. makes Einstein look like a grade school drop out.
as for the lenzless transformer, well it will have to wait another day as all my time is {consumed} with Figueras device.
Sorry pic is incorrect .....see next post.
marathonman
Sorry for the mistake, the cross over Reverse direction points are here.
the transition from High to low and low to High.
marathonman
Doug1 you are Very right. after observing the above graph i agree with you completely 100 %. each wave form represents Two cycle changes {Flux Reversals} so with two wave forms {One Complete Cycle} you will have Four flux reversals.
so it would seem to me that that constitutes double the frequency  ie not 60 but 120 Hz. ???????
antijon
I just wanted to comment about the lenzless transformer. I think everyone means a transformer where the output doesn't affect the input. I mentioned this before, but Mykhaylo Balush seems to have designed a transformer to do that. Because a transformer is a flux linkage device, the primary and secondary will always affect each other. But in his device, he uses 2 secondaries, wired in series to cancel each other out. So if they were matching, there would be 0 volts. However, they don't need to be matching to have the same inductance. One secondary can have more windings, and a higher voltage, but still have the same inductance as the other. This means that there will be an output. The two inductances will cancel each other out, and the primary will see no load.
His first video here https://youtu.be/iGzR0NJ4vRE
Go through his videos and he shows how the secondary has no effect on the primary current.
