ALVARO_CS
hanon:
thanks, I apologize, my PS is from a wifi modem, rated at 12V-1.2A the figure I posted (200mA) is a measure at the input, loaded.
I also tested with a resistor made with the metallic spiral of a hair dryer, min.3 ohm, and so on.
Bajac is right, is should be the most inefficient atempt as it got very hot, which means loses all over !!
In the other hand, I don´t know how to pulse the inductor not having Mr Lenz at the collapse, as the idea of this patent is based in a variable DC current, not falling anytime to 0 volts.
Anyway the learning process keeps on going !
Ariovaldo if just the commutator is that size, I imagine you want to power your own car factory no ? ;D ;D
regards
Alvaro
ariovaldo
Quote from: bajac on September 20, 2013, 12:27:56 PM
Ariovaldo,
WOW! That is not an oscillator but a heavy duty commutated switch. You got some skills!
I wanted to ask you, how did you get the values shown on the voltage column?
Going back to the iron core application, Mr. Figuera stated in his 1908 patent that it can be of a low quality soft iron type. He also stated that a solid piece (not laminated) of iron can be used. His statement can be justified by the use of air gaps in the device. Because the air gaps have much higher reluctance than any low quality iron core, there is no noticeable difference in performance when using, whether high quality laminated Silicone steel sheets or low cost soft iron bars.
Thanks,
Bajac
My first intention with this device is to do a trial using a 3 phase transformer that I have, using Gruamge schematics. Having the transformer in my hands, I simulated the voltage drop using 12 volts battery and nichcrome 16 gauge  wire.
Check out.
ariovaldo
Quote from: ariovaldo on September 20, 2013, 01:37:52 PM
Check out.
I just built the resistors. Next week probably I will test with the transformer connected.
This weekend I will finish the dc motor drive.
Cheers
ariovaldo
Quote from: ALVARO_CS on September 20, 2013, 01:09:43 PM
hanon:
regards
Alvaro
There you go my friend....
That is because you didn't see my Tesla coil... I was forbidden by the city to test it. I heard people saying: -"I don't know, but my sprinkler system start tor works funny, change the time for itself. ....
Ari
bajac
Ariovaldo,
I want to congratulate you for the effort you put on the construction details. You do a professional job!
I would not like you to be disappointed and discouraged from building the device, but it takes a lot of effort to work with such a large core, and then, not getting the results that you might expect.
I want to persuade you to get away from dealing with single large set of coils such as the 25KVA one shown in the photo. The success for building Figuera's devices does not consist in making a single set of large electromagnets but connecting together multiple smaller sets of coils as shown in the 1908 patent. Even though the 1902 patent shows only a single set of coils, I truly believe that to get an operating voltage such as 120Vac, the secondary coils of several sets of the transformers (as shown in the patent) should be cascaded (or connected in series).
I have stated before that the design criteria for building the Figuera's devices are different from the ones used for building today's standard transformers. The most important feature of the Figuera's 1902 and 1908 devices is the use of the air gaps. The definition of air gap is a discontinuity in the iron core path (note that I am not referring to the gaps of the windows occupied by the wire turns around the core). The air gaps are not allowed in the construction of standard transformers and these gaps change the rule of the game for the Figuera's devices. The air gaps are the key feature to manipulate the induced magnetic fields (field of the secondary coils) in such a way as to make useless the typical current ratio formula of the standard transformers. Because the current of the secondary coils (load current) is not reflected back to the primary coils, the small power supplied to the primary coils is relatively constant even under large load currents. The implication of the above is that the iron core of a standard 1KVA transformer can generate more than 25KVA of power when used in the Figuera's apparatus. Once the secondary voltage is established in the Figuera's devices, the main limiting factor of the output power is the amount of current that the secondary wire can handle. That is the reason why the Figuera's apparatus is known as his INFINITE ENERGY MACHINE.
The above sounds like a heresy but it is true! Because standard transformers do not have air gaps, the reluctance of the core magnetic circuit is very low and a relatively low ampere-turn (magneto-motive force) can generate large quantities of magnetic flux lines, which can force the core to reach magnetic saturation easily. As a matter of fact, the standard transformers are designed to work at the knee of the saturation curve where they are more efficient. That is the reason why an iron core used to build a 1KVA unit cannot be used to construct a 25KVA standard transformer. Because in standard transformers the ampere-turns of the primary coil increases with the power demand of the load, the cross sectional area of the iron core must be increased accordingly for the 25KVA unit. Otherwise, the 1KVA iron core will just saturate beyond the knee of the saturation curve and the increase of the primary ampere-turns will not necessarily translate in an increase of the magnetic flux through said core.
On the contrary, the air gaps present in the Figuera's devices make them to operate at the very low part of the magnetic saturation curve. It is very unlikely that a 1KVA iron core used in a standard transformer will saturate even under a 25KVA load. Because the load is not reflected back to the primary coils, the ampere-turns of the primary coils do not substantially increase and stay constant.
The following is my recommendation:
Use an iron core with relatively small cross section, say not larger than 2 inch square and with gap windows large enough to accommodate the coils. The material can be laminated Silicone sheets or solid soft iron. You must be careful interconnecting the core sections when using solid soft iron materials. Do not add extraneous material between the sections such as welding. All the air gaps must be kept to a minimum. For the 1908 device, use a paper thin material to join the core sections. For the 1902 device, the dimension of the air gaps should be just big enough to fit the secondary turns. Because the air gaps of the 1902 device are larger than the gaps of the 1908 one, the primary coils of the 1902 device will require more turns.
Because of the air gaps, you will need a much higher ampere-turn for the primary coils just to create a small magnetic field. You can use wire gauges such as #18 or #20 AWG for building the primary coils. Even though I have recommended a minimum of 300 turns, do as many turns as you can for the first set. For example, if you can do 600 turns, incorporate middle taps for 300, 400, and 500 turns. For the secondary use no less than 200 turns of #14 AWG. Recall that you do not want to use a thin wire for the secondary because the power output for this device is limited by the gauge of the secondary coil. For the first set I would recommend to do no less than 350 turns for the secondary with middle taps at 200 and 300 turns. The flexibility of choosing primary and secondary taps when performing the testing will be invaluable.
Build and test one set of coils first! Once you know the coil taps that produces the best performance for the given core, you can proceed for the construction of the remaining sets. For example, if the test of the first set indicates that the best performance corresponds to taps that make the secondary coil generates 20Vac, then; you know that five more sets are needed to make a unit with a rating of 120Vac.
I hope the above description can guide you in the right direction.
Thanks and good luck!
Bajac
