antijon
Reactance. Due to self induction every coil powered by a changing current will exhibit reactance, whether it's pulsing Dc, or Ac.
In a generator, there is zero reactance. Because velocity increases emf, we can say that as a generator is turned faster, it produces more power. However, with a transformer, it's the opposite. As frequency increases, reactance increases and power transfer drops. This is due to current lag in the primary and the secondary load doesn't change this.
So you can feed a coil any voltage to make a transformer, but to make a generator it has to have voltage and current in phase. In your design, yes you can produce the proper dc pulses, but without correcting the reactance, as you increase frequency your power will drop.
The reason Figueras commutator is important is because it keeps the current in phase. I didn't realize it at the time, but I think I successfully replicated the Figuera generator with a sliding resistor. As the slider was moved faster, the output increased. This is also why I agreed with hanon's idea, the DC field prevents reactance. I'm just saying, there's a thin line between a generator and a transformer, but killing reactance is certainly a key.
ignacio
Muy bueno Antijon, ahora simplifica, incorpora... con condensador (atrasa), reactancia (adelanta),
Very good Antijon, now simplifies incorporates ... capacitor (delayed), reactance (forward)
marathonman
Yah!  good luck with that dogma education you have. you listen NOW !
MAGNETIC "AMPLIFIER" !
marathonman
Would any one know what the maximum flux a 99.8 pure iron bar can handle ? the sizes are 1.5 inch and 2.25 inch diameter.
i can't find ant thing on the internet worth beans and i would rather not guess in this area.
any help would be very much appreciated.
