0 Members and 35 Guests are viewing this topic.
Schiko
Quote from: bajac on September 27, 2013, 07:10:05 PM
@ Schiko,
I want to congratulate you for your efforts. I think you are in the correct path.
You may ask as many questions as you like. The nice thing about a forum is that you can get different answers and views. That makes it more exciting!!
On the other hand, why do you think the Figuera's device would not work? Did you replicate it? If yes, could you post the device that you did your test?
I cannot say the same. I tested the device and the results were like nothing I had experienced before. I was telling Hanon that the short circuit test soldered the secondary leads together. I had to shutdown the device to cut the leads. I was not able to measure the short circuit current because I did not have an equipment with such a high current range. But amazingly, the primary current did not change, it just measured about 1.3A DC before and after the short circuit condition. During the short circuit condition, the transformer started vibrating and produced a loud Humming sound. I am so disappointed for not following the teachings of that setting. That is why I am rebuilding the tower to match the coil turns of that setting.
Hi bajac
Thanks for your words.  8)
See, when I say "doesn't work" I mean "not to produce more output than input" However my current device worked fine but didn't hit more than 100% yield.
Unfortunately I have no photo of the first device that did not work, who wants to show device failed.
You can show some really small device running on autorun, that's all I ask so I can cheer me up.  :'(
Your device that you got high current which commutator you used, mechanical or electronic??
I also can get high currents in mine, just depend on the coils that use, but never greater in power output at the imput.  :(
Excuse the writing ... that translator I get crazy he insists on changing the words I want to write, but I'm learning heheheeh
bajac
Quote from: john-g on September 23, 2013, 09:44:09 AM
Bajac
It looks as though some excellent progress is being made here. You say that standard transformers do not have air-gaps, however normally they are built up of laminations.  Although these are primarly to stop eddy currents, do not the small gaps between the laninations, caused by the coating of varnish not add in small air-gap?
Kind regards
John
John,
The lamination is done such that a low magnetic path is formed in the direction of the flux lines. There is no insulation added to the connection between two laminated parts forming a closed magnetic path. But, the insulation is added between two parallel laminated parts configured in a closed path. Because the Eddy currents are induced perpendicular to the path of the flux lines, the insulation between parallel lamination is an efficient way for minimizing these parasitic currents.
The standards transformers are designed to have a minimum core reluctance, and therefore, the goal is to maximize the core permeability. The consequence of the latter is that the core will have the maximum number of magnetic flux lines for a given ampere-turn (NI) of the primary coil. And because the cross-section of the core is just large enough to avoid saturation (at knee part of the saturation curve), the maximum cost/benefit is obtained in terms of KVA to pound ratio. In other words, the design criteria of standards transformers is to maximize the power transferred to the load while keeping the size of the transformer to the smaller possible dimensions (volume). Please, note that the configuration of these transformers will always have an efficiency lower than 100% as explained in the document describing Figuera's 1908 apparatus.
Bajac
bajac
Quote from: Schiko on September 27, 2013, 09:02:14 PM
Hi bajac
Schiko,
You seem to be a little disappointed with your experiments. The major mistake you made was not to disclose your setup even if it did not work. You are not the only case. I hear people complaining that they had built the Figuera's apparatus and no results were obtained. When I asked to post photos of the setup, the devices did not really follow Figuera's teachings.
I could tell you that the Figuera's devices do not operate at high frequencies.
A big mistake I made was to dismantle the unit that I showed in post #58 before completing all the tests!!!
Bajac
Schiko
Hi bajac
Disappointed, a little, but I still have hope!  :)
I don't want to create controversy that's enough the discussions at the beginning of the forum, but from the beginning nobody was able to show a single device running on autorun, it seems odd to me because the patent claims that there will be abundant energy in fact I think there's something else on the device built by Mr. Figuera that is not in the patent that it would be very natural and whatever the secret was with him to the Tomb, I'm not affirming anything but that's what I think.  ???
But I didn't give up, since nobody's going to show me a device as is in the patent running on autorun, keep trying in other ways, not following the patente literally and searching for the secrets...  ::)
cheers!!!
forest
Hi
Do you have any link to detailed explanation about laminated core ?  I have to understand how it is build, work and how it is produced (the steps involved).
