NRamaswami
The one person I respect in this thread is Mr. Antijon who spoke the truth that the primaries when given in parallel will have an amplifying effect on the output. I was aware of the same having done many experiments.
The only pieces information that is truthful in the Figuera patent description is that variation of magnetic field strength is sufficient and rotation is not needed and the not so clear image of the electromagnets. Rest of the information is misleading. The output voltage of 550 voltage disclosed in 1902 is also correct.
I do not intend to post or reply here. Simple fact is that the output voltage and amperage must be in excess of input voltage and amperage and it is easily achieved by using thin primaries with high resistance and thick secondaries with lot of turns. The output voltage has to be higher than the input voltage.
Even if I slog it out here due to electromagnetic radiation problems this is not going to be a common device. I intend to work on an Earth battery and no longer going to do this. It is very unfortunate but no one wants to live near high electromagnetic radiation fields. The whole device needs to be put inside the Earth for it to be accepted for common usage.
Thanks to all who responded either positively or negatively.
Doug1
Faraday cage? It needs a box anyway might as well be one that does more then just look pretty.
massive
IF there is input power , where is it coming from ?    circa 1902 canary islands .
has anyone even had a look at Canary islands ?    google it
its doubtful they even had a generator in 1902 .  what fuel would it run on ?
what is the suggested freq out put of CF , 50 , 60 hz ?      to power what ?
1902 canary islands , no washing machines , no tungsten light bulbs , no fridges .   AC motors ?
gyvulys666
to massive :)
everything very simple :) in these times maybe earlier "all" understood that if they let it loose then there wont be anyone who will be cutting grass for free by their castles :) and they started to teach ALL bullshit till these days :)
hanon
This what you can get just by adding a capacitor  to an AC signal. In my case by using 95 uF to feed my coils, two groups of coils, each coil  with 23 mH. Voltage measured in each side of a 0.47 resistor. Just for information
