0 Members and 68 Guests are viewing this topic.
marathonman
I'm in the midst of checking that theory. according to Doug the heat issue is the reason the cores were separated so the primaries are not effected from the secondary.
i posted a pic of my cores with bobbins but have to wait till payday to finish my winder tension tree. all parts bought from Lows or home depot.
i will post pics when its done and of the cores when they are wound.
when i test the one core theory and i have heat issues i can always cut the core.
Massive;
Canary islands in 1902-08 that would be DC only, AC was not introduced to Canary islands  till later after Figuera's time.
Doug1
There was also the Spanish American war going on at the time. So when was the war of 1914 anyway?lol You wouldnt believe how many people get stumped by that question.
  Marathonman
  Man is standing in a field hunting with a rifle. He slings it over his shoulder backwards to shoot behind him, He is using wad cutters so to compensate for shooting backwards he loads a shell that has the bullet inserted into the shell backwards. Which way is he shooting? Is the bullet going backwards?
marathonman
  Doug i don't hunt and couldn't even tell you what a wad cutter is.
the name wad cutter sounds like a brand of condoms. ha ha ha, yah i know i'm throwed to the curb.
I'm assuming your referring to my avenue i chose with the cores.
hanon
I must clarify my last post: I showed two unphased AC signals, but I am not using AC in my tests. It was just to show that there are different methods to unphase a signal from the other. It was just an example. Figuera used a always positive signal and this is what I am using. His patent is based on moving the field no matter how, so the signals must not get reversed at anytime.
Doug1
Marathonman
  Back emf for the sake of simplicity follows rules which are conditional and might not always act the same way under all conditions depending on what those conditions are.
  The difference between forward and reverse and the reason for one or the other can be altered by changing the conditions. A wad cutter is a flat faced slug that has no front or back they are the same only the motion has relevance.
