0 Members and 113 Guests are viewing this topic.
MagnaProp
Quote from: norman6538 on April 15, 2016, 08:27:08 AM
No moving parts - selfrunner.......
So why don't we see these everywhere in 2016?
Norman
For the same reason Gary Webb was able to commit suicide by shooting himself twice in the head. Devices or people that can cause to much disruption can quickly go bye bye. Lots of economies rely heavily on exporting fossil fuels. When Saudi Arabia has to build large solar power facilities in order to keep making money exporting fossil fuels instead of using it up themselves, you know it's a rather important product that powerful people want to keep in circulation.
So far the Figuera device discussed in this thread is one of the best devices I have seen that makes sense to me. I see lenz in the system. However, the lenz appears to help it instead of hurting it.
NRamaswami
I unfortunately have to make an admission of failure.
Both Ramaswami device and Figuera Device works well and produce COP>1 under the following two circumstances.
1. When the core is saturated. The core that I used is not a solid iron core but core made up of iron rods. This rod has significant air core component of at least 20% of the core and so we are able to go to high Tesla ranges without melting the iron. But the unfortunate problem is that the core at such high saturation is said to output very high Electromagnetic radiations which are inimical to health. Therefore I was advised that I should not go beyond 1.2 Tesla. I'm unable to get COP.1 at 1.2 Tesla.
2. There is a type of winding that I tried that produces COP>1 but again that type of winding is said to create 100 times more inimical radiation than the core at saturation.
3. It is not possible for me as indicated in the Figueras patent to get COP>1 or self sustaining devices under the safety margins. No hazard to health, 'environment and safe and sustainied operation of the device are the rules that I had to meet. In spite of my high efforts I'm unable to do it.
4. Unfortunately when I connected multiple primary coils in parallel the input voltage came down and input amperage went up. The secondaries are not merging. If we take the output value of each individual secondary I was able to reach 82 volts and when I connect the multiple secondaries together in series the combined voltage is never the combined value. It gets combined to produce a super high voltage only when the core is saturated. Larger cores draw amps like 25 or 30 amps from the mains. 200 watts lamps light up as if they are 500 watts lamps being powered under high voltage.
I have to admit my failure here. I have checked as Figuera type and as Ramaswami type and I used AC and I repeatedly face this problem.
I will test for one more time with pulsed DC using a special circuit where the output which will power the primary will be in 25 Khz frequency, with an output voltage of 500 volts and we need to check what is the amperage drawn. I'm going to use Mosfets or transistors that can handle high current draw and let me see if it works. The circuit will keep the pulsed dC at +5 to the top of the sine wave and it will never reach zero. This will not allow the magnetic field to collapse. Lenz law is not supposed to come unless the magnetic field collpases and this is the only test that I have to do.
If this does not work, I intend to stop my experiments and focus on my Practice.
hanon
Quote from: NRamaswami on April 17, 2016, 07:05:42 AM
.... melting the iron. But the unfortunate problem is that the core at such high saturation is said to output very high Electromagnetic radiations which are inimical to health.
You are a scam artist. Your post are just to discourage people from replicating this device. All in your post is a big lie. Your are a brake in this project. Nothing is useful from your posts and just miguiding points as saturating the core (nonsense)????, melting the iron (stupidity)!!!!, radiation (a big lie) !!!!
I may guess that you are  misguiding people because you have some interests that nobody may be able to replicate this system.
I have a private message from you some time ago telling me that the advice about radiation was a lie.  In that time I realized you were a scam artist. That was my fault for not uncovering you. I am sorry for not telling that in the thread then. But never is too late.
You have come back to use the same argument to create terror. I am going to search for that message and I will release the text in short in the good of truth and justice. People will see the kind of person you are.
Bye ... bye
marathonman
Oh, you just now realized this.....em,  it's about time you pulled your head out of your back side. Hanon has awaken.
MagnaProp;
very good observation and totally correct.
i also believe you don't use Indian tech support with an assumption like that.
NRamaswami
Quote from: hanon on April 17, 2016, 07:55:27 AM
Bye ... bye
Hanon:
I have only told the forum what I have experienced and what I have seen. How can this prevent others from doing the experiments. Please check with others what is the safe margin for transformer cores (1.2 Tesla is what I'm told). COP>1 comes for a few seconds or 1 or 2 minutes but the iron roars. That is not safe is any one who does the experiment can see.
I'm least bothered about titles such as scam artist..You had not done the kind of large devices that I did. You had not suffered in the way I suffered.
We are dealing with Electricty at low frequency here. High amperage and significantly high voltage. If the results come I can say yes the results come. If results under safety conditions do not come, I have to tell this as well.
You must also remember that I'm not a scientist nor an Engineer. If I have some negative report from an experiment how does that make me a  scam artist.  I speak the truth.
I do not block any one from going ahead with these experiments and I wish all Success. If I cannot do some thing under safety conditions laid down what can I do? I have to say this openly.
