0 Members and 103 Guests are viewing this topic.
marathonman
Loner:
I to believe the VTA works on similar concepts as the Figuera device except the Figuera device is low frequency drive and higher amperage output. yes that's low frequency drive as in Figuera did not have a 20,000 rpm DC motor in his house, Rswami. but good luck all the same.
i think FS was a genius way beyond TB.
it's not really b field's cancel as per say because Lenz is used to Figuera's benefit.
we are all still learning and a few are way over our head's but i will not stop till it's done.
Their is only one person on this forum that has a full grasp of part G  and know's the significance or importance of it and i don't think i am to far behind in my description.
Quote; "The principle as Patrick reiterates is common. Sharp high speed unidirectional pulsed dc of high freqquency of the order of 1 Mhz are needed to access zero point energy. "
Totally opposite from Figuera's design.
hanon
Loner,
As well as the similarities to the VTA, I find also many similarities with the Magnacoaster patent by Richard Willis. He also used two confronted north poles with a coil in between and distorted their fields with an external signal. I guess he also based his generator in obtaining flux-cutting induction by moving the field lines.
http://diysome.web.fc2.com/FE/Hajime/Willis/WO2009065219A1.pdf
This how it is said to work:
"We pulse an electrical charge into a set of coils that are wrapped by neodymium magnets.
This pulse dissipates the internal field of the magnets.
When the pulse stops, the magnetic field returns creating a supercharged electric output.
We then collect this high output back from the coils.
This high output of power is then rectified and returned to the battery that it came from"
A deja vu?
What do you think of this patent?
Doug1
Hannon
You can always tell when someone was charged by the page for a patent by a greedy lawyer. It turns into a novel.
norman6538
Hanon thank you for the Willis patent. interesting points.
1. date 2009
2. the word overunity on p. 1
3. like poles of magnets
4. gap at magnet 2.
Sure has the Figuera likeness.
So I would summarize this as "permanent magnet enhanced/multiplies backemf".
And since this was dated 2004 it should be everywhere by now but I don't see
it so.......that means............
Norman
marathonman
It means he had problems with the unit overheating and more then likely threatened with his life from the power cartel's.
Richard Willis device is pulsed and has a ringing effect in his core and if Figuera had this all induction would stop.
Similarities just ended.
