NRamaswami
Hanon;
I find it hard to believe that Bankers who bought the 1902 Patents and shelved them would not have altered the 1908 to 1914 patents. It could have happened only if they were not following it. But for a century they were forgotten and never reported. We do not see any report of the 1908 device in newspapers and certainly Figuera or BuForn would have tried to get it publicity so at least BuForn the financier of second set of patents could get money and recover his costs. This is where I find it difficult to believe that the patents were left intact for more than 100 years. But this is a doubt. Nothing more.
The strange thing is that the principle works. Even in AC the principle works. But there is Lenz law effect until we reach saturation. This I can confirm. Probably the backemf was still there in my coils but because the primaries are thin and secondaries are thick the backemf was overcome by the way we wound the coils when the core reached full saturation. If backemf is avoided today we can make it a simple device.
There are a lot of other concepts but without testing them and verifying them to be correct I cannot agree to theories. let us wait and see what Marathonman produces.
Patent shows resistors. I'm confused by Marathonmans statement that there are no resistors and Part G is different. Let us wait and see until Marathonman produces his device and demonstrates it.
marathonman
the Patent is using a drawing to conceptualize the function of part G,  if your Brain is to weak to wrap around the concept then i am waisting my time on this forum.
OPEN your mind bone heads  and study part G if possible.
bajac
This is a waste of time. At this point, if you do not understand how a mechanical switch or collector works, then you have a problem.
Because the switching is make-before-break it implies that the element will be temporarily shorted out. If this element is an inductor in lieu of a resistor, you should expect substantially more sparking/arcing.
Who is the bone head now?
I am stopping this nonsense argument now. Is your goal to confuse the people participating in this forum?
NRamaswami
In view of my inability to either use the rotary device or use the Full Wave Diode Bridge Rectifier that drew very high current from the mains I learnt few lessons.
1. If we use AC and multiple secondaries we have the problem of secondary voltages not merging.
2. To use pulsed DC through Full wave Diode Bridge Rectifier we need to get a High Resistance coil but that will also allow adequate current to pass through it. If we have 1 to 4 amps current to flow through the coil then the magnetic field can be increased or decreased at will. Unfortunately I was unable to find any suitable resistor.
3. I have just found a resistor. It is called NiChrome wire. These wires come in their own gauges and are used for a different purpose. About 100 feet of wire can have 100 ohms. The wire can also allow up to 5 amps. Both insulated and uninsulated wires are available. We need to wrap them as resistance coils with spaces to avoid shorting if they are uninsulated and then wind plastic sheets over them for the many layers of the coils. Even steel wire is sold by some vendors and are available on Ebay but NiChrome that contains Nickel, Chromium, Aluminium or Nickel Chromium and Copper seems to be the best. Price is not very high.
4. A Diode Bridge Rectifier with this kind of resistance coil can be used to send 110 volt and 100 Hz and 1 Amp pulsed DC safely to the coils. The number of turns of wire will decide the magnetic field strength here. A Flyback diode can be used on the primary to reduce the backemf on both primaries.
5. I'm advised that in this kind of pulsed DC, the voltage of multiple secondaries can easily merge by connecting the wires in series through fast discharging diodes. We can make it interrupted DC as used by Figuera by using a capacitor and a spark gap in parallel. This will increase the Frequency further but because this is interrupted DC the induction in secondary will be there.
6. Pity after I have stopped I get this information. But I'm sharing it here so others can benefit.
marathonman
"Is your goal to confuse the people participating in this forum?"
No sir your doing a good job of that on your own from the start.
Rswami; i posted a year ago about Nicrome wire, guess you missed that but that's before i found out about part G's REAL IDENTITY.
Quote from Patents: To fix ideas is convenient to refer to the attached drawing which is no more than a sketch to understand the operation of the machine built using the principle outlined before.
now i suggest people start researching a little more then going by a drawing that says it's just a drawing or listening, following someone that goes by a fricken drawing.
that's just plain stupid and foolish.
so again i say lets hear your Fairy dust version of part G or would you rather we click are heals together in the land of OZ.
