0 Members and 128 Guests are viewing this topic.
jegz
Marathon man. The concept is the same..in actuality figuera is the somplest and is the kind of machine that could solve the problems of a rural villager who doesnt have time to learn zero point resonance  mumbo jumbo.The whole idea of this rendition is to use the oscillator to distort the position of the blochwall and induce current in L2 which are counterwound/bucking coils hence cancel back emf. regarding output that is dependent on the combination of variables used.
marathonman
Similar Yes, using another coil to manipulate other coils what Figuera achieved with just two coils working in unison. good set up though and your right Figuera is the most simple of them all. it's just most can't understand the logic behind part G being thrown off by the drawing and Patent wording even though it is very simple set up of using magnetic field to manipulate currant.
Figuera even said it was so simple he couldn't believe no one thought of it before.
I'm building both moving and non moving part G, thinking of finishing non moving first but have core for both now. i have studied part G for quite some time and figured out that i can use Transistors on the high side (ONLY) to mimic rotation and not interfere with the kickback into part G from the declining electromagnets being shoved out of the secondary core feeding part G every half rotation. (NO IC's CAN BE ON THE LOW SIDE)  field rotation in part G will still take place and other functions, i just have to make sure that the primaries are balanced just like Doug has stated.
jegz
just wondering though how I would go about creating a true sine wave from part G such that the induced current wont need to be passed through rectifier then an inverter to give a frequency that wont damage sensitive equipment
marathonman
Why would you need a true sine wave from part G? part G is DC feed and the frequency is controlled in the original part G by a DC motor. the speed you set of the motor or high side transistors is what set the frequency in the secondary output.
if you set the motor or transistor timing at 60 rpm/hz then your output from your secondaries will be 60 hz as the polarity if i am correct will change every half turn of part G just like a sine wave so the need for a inverter is not necessary.
i think you are getting the two circuits mixed up, part G and the primaries are DC. the secondaries are AC so that means the frequency is controlled by the motor or Transistor timing.
i hope this give a little clarity to the situation.
MM
jegz
youre the one who doesnt understand what I mean..even a conventional generator putting out 60 hz may not be true sine wave and  could potentially damage sensitive equipment hence needing conversion to dc and back to ac with a true sinewave inverter...hence the term inverter- generator producing 'clean power'...what Id love to see is actual solid state  circuits at part G that (assuming L1 and L2 are identical in length that produce a perfect sine wave, hence reducing the components needed to build this device.
