0 Members and 137 Guests are viewing this topic.
marathonman
Well Doug you were right, it sure didn't take long for AC to pop up.
Are you kidding, comparing DC being varied to AC is like night and day and you have to be blind not to see the difference.
and for everyone's information the Figuera device does NOT collect BEMF. "WHY" because the currant is constantly supplied to the Primaries just varied in intensity so NO BEMF EVER occurs. what does occur is the declining Primary electromagnet is shoved out of the Secondary and feeds part G.
IF BEMF ever occurs in the Primaries it means that the currant was not maintained in a proper manor so outlined by Figuera and all induction will be lost. AC will kill the induction from the primaries because of the fact that it takes to long for the domains to flip. if constant pressure is not maintained between the Primaries induction WILL BE LOST.
so go ahead with you AC contraption, i would love for you to spend lots of money on it. in the long run all i will say is "i told ya so"
the Patent it's self and all posted research information points to DC but do as you must.
hanon
IMHO Figuera device nullifies the Faraday Law because one side of the coil (from one side to the point of collision of magnetic lines of the two repelling fields) the magnetic field is increasing (dB/dt >0) while in the other side of the coil the field is decreasing in the same amount (dB/dt<0). Therefore the total effect due to the Faraday Law is cancelled out.  Faraday Law is the one with a minus sign    emf = - N • A • dB/dt   , but in this device the minus sign (flux linking induction) is cancelled out totally or partially.  Induction is just done by flux cutting which is represented by the Lorentz equation   emf = B • v • Length  , and this equation do not have a minus sign. For me  both equations are different: Faraday Law is based on the Maxwell equations, while the motional emf equation is based on the Lorentz force, which is not part of the Maxwell equations as far as I have read.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elevol.html#c3
Doug1
I think your interpretation of what you read is wrong. If it feels like it was written a little odd it's because of a  failure in the writing to lock down the frame of reference of the observation with clarity. Anyone could speak for hours about two train engines locked together facing each other traveling down a train track with out any distinction between engines. Chances are the interpretations will more often be wrong then write. Add in the track is a circle and in an attempt to find clarity time is introduced. More isnt always good unless you want to cover it from every frame in order to prevent more confusion.Less might be in order.
  Marathonman
  I thought you had a better grasp on the principals of the mag amp the dc from ac patent and a complete understanding of the variac and how it works. Specialization is a sociopolitical tool of controlling the general population. To a hammer everything is a nail. The hammer thinks it has it going on and can do anything just by hitting what ever it is. If this was a room full of medical doctors the scripts would be knee high wall to wall and when that fails start chopping out organs and flesh. If the patent says the output is running the load and suppressing the input and in a typical rotational type using the output through a regulator and supplying itself in well known ways. Whats the best approach to consider?
marathonman
Who the hell EVER said i had a "COMPLETE" understanding, it sure wasn't me. as for the mag amp's i have many cores i have been tinkering with and am almost their with the Tesla patent. as for the Figuera part G i am still struggling with the self running part, as if you don't already know that . more then likely it's through the Core of part G. that is the last of the puzzle as far as i am concerned.
"Specialization is a sociopolitical tool of controlling the general population." WTF is this shit.
Erfinder: you are not telling me anything i don't already know. Yeh sure anyone can blast an F-in coil up with any kind of signal and get some kind of output but i guarantee you will not get as much as the proper timing for the Figuera device. the link i posted from Hanon shows the Primaries at work over the secondaries. this is exactly what is going on in the Figuera device and you sure are not going to get that precision with YAH HOO timing.
Good luck buddy.
i will believe it when i see it.
marathonman
I to think your opinion is worth Squat but in the long run YOU have yours and I have mine. Ranswami will be glad to help you.
end of conversation as i have better things to do like build the real part G.
Good day sir.
