marathonman
Part G is a continuous wind and the reduction of currant is dependent on how many winds are on part G's core. i do not have the math prowess to calculate that so i had to take the hard road and wind then test, well the first time was wrong so i added a few more winds and that was it. see both primaries have to be balanced and has to match the other exactly when taken high and low, if not the pressure between them will drop and induction will fall to half of what is achievable. you have to remember part G or rather the whole system is DC and part G is basically a Variac but with DC.  the opposing magnetic fields will help regulate the saturation of the core which will regulate the currant on an continuous basis.
the pic below is a simple test from a friend that suggested the use of a paper clip on a straw to test where the two fields are at all times. the metal paper clip will follow the two NN fields as a visual indicator of how far your fields move and to let you know weather or not the fields clear the secondary.
William J Hooper did a simple table top demo in one of his lectures that proved the figuera device is NN design in an pure B x V device. the pics below prove scientifically with out a doubt many, many years later that Figuera's device is NN orientation. according to Hooper when two North opposing magnetic field are present near each other the B fields are cancelled but are additive. when one is moved at a certain velocity in and out from the wire and the other the opposite a pure B x V field is created. to be precise B X V = (-B) X (-V).   This will cause the B fields to be cancel = 0 but both products are positive and additive as explained in the pic below.
the only difference between Hooper's demo and Figuera's device is his test has the magnets vertical and Figuera's were Horizontal. their is no difference in the outcome the results are the same B X V = (-B) X (-V) both positive and additive.
the other pic is the proof that NS electromagnets are not possible in the Figuera device. if the north magnet is taken high and the south magnet is taken low the currants are the opposite direction so the cancel out allowing only a small currant to flow because the peaking magnet minus the declining magnet will amount to almost nothing. that is why EVERYONE that uses NS will end up with nothing because they paid NO attention to spin, B field's, and induced direction. assumption will bite you in the ass every time as i am totally aware of this.
output will be normal AC from the secondary at what ever frequency you so choose, assuming you core will allow it.
darediamond
Quote from: marathonman on June 26, 2016, 02:18:54 PM
The Figuera device is also ZPE harvester which needs high frequency to lower primary input current at high voltage.
The part G can be replaced with a DC Pure Sine Wave Variable Frequency DC to AC inverter as WHAT THE PART G is ensuring is constant frequency that does not nosedive to 0  before it pick up over and over.
marathonman
Ac can not be used in the Figuera device as been said MANY, MANY times before. the field CAN NOT build up fast enough.
your interpretation of the Figuera device is all wrong.
Scientific proof has been laid out and yet you still chose to ignore it.
all i can say is good luck fella you'll need it.
dieter
I think the term "ZPE" is used quite inflatory these days. It is the name of an anomaly, in which helium, contrary to fundamental laws and unlike all other elements, remains liquid at zero degrees kelvin. Despite the lack of thermal energy, the day is saved due to zero point energy, even tho nobody can say what it actually is...
Hey wow you guys are still onto the figuera project. That's cool.
When watching fields under that green magnetovision foil, I noticed when N vs N is very close, the fluxdensity can be highly increased. And a coil left of the frontline must be moved only a few millimeters to the right for a complete polar flip.
Anyway, wish you all the best. And remember, it's about the result, not the talking.
