darediamond
Quote from: marathonman on June 26, 2016, 04:45:53 PM
Ac can not be used in the Figuera device as been said MANY, MANY times before. the field CAN NOT build up fast enough.
your interpretation of the Figuera device is all wrong.
Scientific proof has been laid out and yet you still chose to ignore it.
all i can say is good luck fella you'll need it.
Marathon,  you do not seem to understand what I am hammering. How do we in this modern time make the primaries consume less Wattage while switching them to and fro to energise the middle output coil?
Is there no solid state alternative to Part G because from my practical research, low frequency will make the primaries consume high wattage?
How will lenze be cancelled if he coils are wound in same direction as you have been hammering that CC to CC or CCW to CCW are the correct positions?
Doug1
When did Figuera mention cancelling Lenz Law? Your fixated on something you dont even clearly or completely understand. Even if you could cancel it in a generator you wont cancel it in the load that is attached to the generator so how would that work exactly? Or do you intend to have a free wheeling gen that does no work. Even Harry Potter had to wave his wand and speak his spells to make something happen. the only way to have no resistance to change is to do nothing and change nothing.. Can you recognize when Lenz has been eliminated?
jegz
Quote from: darediamond on June 27, 2016, 02:06:50 AM
I think its been stated enough times that the induced coil appears as a ghost trace on oscilloscopes in the figuera setup. however if you must I see no reason why a bucking coil shouldnt be applicable in this case...centre point being pos and the two ends terminated as negative
darediamond
Quote from: Doug1 on June 28, 2016, 07:52:58 AM
For a certainty, youbare a spammer operating 2 or more accounts on here for the sole purpose of misleading. The will be the second time Dough1 will bebappearingnas Marathon!!
You can not event cover your tracks smartly.
I think someone else ough be employed to replace you on here your Committee Of 300 paymaster.
Doug1
deradiomond
Thats pretty funny i needed a good chuckle. Everyone has to be something even if it is to be consistently wrong as that thing they are. On the upside you are consistent.
