0 Members and 28 Guests are viewing this topic.
NRamaswami
Mr. Darediamond:
I very rarely come and check this site nowadays.
If you are using identical poles as primary NS-NS-SN or N-Y-S as it is claimed with a straight bar in the center the output as I have measured is zero wattage normally. To check when the output can come we tested with a very large magnetic core and we managed to get some output in the secondary but the efficiency was very very low. For the two magnetic fields cancel each other out.
However it is possible to take out significant electricity using identical pole primaries to oppose each other. What happens then is that the magnetic fields will repel each other and move side ways. The closer the two identical poles the greater is the magnetic deflection. You can test this with two permanent magnets. Identical poles will repel each other.
The simple trick is to put a Cross like strucutre in the middle of the Y coil. Then the secondary will have three cores one in X Axis, one in Y Axis and one in Z axis. If you wind coils on the Y axis core and Z axis core and connect them you would have a Lenz Law free output. The Lenz law effect is not present for the magnetic field is deflected or scattered from the primaries and does not go back to the primaries. But putting this up is a little complex and difficult exercise. The secondary must be inside the core dia of the two primaries and must be cross inserted at the middle and windings must be on the cross. In order to increase the magnetic field strength you can use multifilar coils.
If pulsed DC is used the output of many of these secondaries can be combined and as voltage increases in pulsed DC amperage also increases. The primary input would be very negligible and secondary output would be higher. This is one of the two ways the identical pole primaries opposing each other can produce significant output. However the Figuera device does not show this cross in the middle but shows a straight core. Only a NS-NS-NS type of arrangement would work for that geometry.
You can easily test this and report the results yourself. I'm unable to replicate these arrangements as I'm not presently well. Any one on the forum can test this.
I have not tested the specific arrangement that is being promoted by Mr. Marathonman and therefore I cannot say any thing about it. Experimental results always triumph theoretical postulations. We can only learn from such experimental observations.
Regards,
Ramaswami
marathonman
words of wisdom and scientific truth shall set Figuera free.
darediamond
Quote from: marathonman on July 26, 2016, 07:16:01 AM
I don't have to cover my tracks, people make mistakes. it is all about learning from them in which i did and then some. my knowledge of the Figuera device surpasses most everyone on this forum except Doug. why ? because of my desire to succeed and learn.
i freely share what i have learned and if that's a crime then i am guilty as charged.
i would suggest you quite living in the past and get back to your research.
i really doubt your on this forum to learn though, your actions say otherwise. this is probably why no one listens to you because of your ill intentions.
i almost feel sorry for you, NOT!8
good day Mr. darediamond
Who needs to be felt sorry for if NOT you Marathon man, the Kite.
You are yet to learn from your childish blunders because you are still stinkingly repeating them.
Ever since you have been on this thread, Never have you shown a live part of your Figuera Gen nor a Machine you build to make it coils or any other parts.
I asked you earlier to show people on here homebuilt part G or in whole your working Figuera Generator but you will only resort to insultive replies.
What the hell is your problem?
What?
I am a Builder. An hardened self-trained one and you as well thouhg arrogant is aware of that. The very First or Second Post I made on this thread which you insulted me about proves myself acclaimed status. I designed tools and machines on my own as well as learning from others. SO LIKE I TOLD YOU SOMETIMES AGO, YOU ARE NOT IN ANYWAY QUALIFIED TO TEACH ME NOR TELL ME TO GO INTO RESEARCH. I am not all knowing mind you because I Dare Diamond is like every other Man is imperfect. However to learn from someone like you requires one eye closed and one eye Vividly opened.
What you are sharing is outdated. The Part G is cumbersome. High Frequency AC from a Pure Sine Wave Inverter is all the Figuera Gen Needs. The Capacitance of The Primaries and the type of Core used would as well determined the Output.
North to North is hogwash because the saying which I is true is "DO NOT KILL THE DIPOLES" So the lezless effect in the center will be high and low as the AC switches one side to North and the other to South and Vince versa at each cycle. So the attraction will be in left at one cycle.and rigth because North is the Husband while South is the Wife to say it in a more simpler manner.
Garry Stanley motor as well uses the same Principle of not killing the Diapole.
Where does your own Odd theory comes from?
Bucking Coil is only useful for the Secondaries which can be wound under each Primaries and still tap the Center too which will then makes the Output secontons 3.
You DO NOT BUCK THE PRIMARIES AND EXPECT ANY USEFULL OUTPUT.
SHOW US YOUR WORKING MODEL THAT SUPPORTS YOUR N to N claim. But I know you will never do that.
Wanna insult me again to keep up with your lies spreading?/
Let's hear you....
marathonman
It's obvious you can not nor will ever be able to think out side the box. no abstract thinking so your Figuera device will never come to fruitation.
just because you can't understand Figueras device doesn't mean other can't.
Seeking4thetruth
Could someone post a completed and updated circuit diagram of the Figuera's device, taking into account all the discoveries already made in this thread, please?
