0 Members and 44 Guests are viewing this topic.
hanon
I have just read that Utkin has ordered to remove his documents from Patrick Kelly ebook. Chapter 22 was the key for many OU devices as Figuera generator and many others: two magnetic fields in repulsion being moved or distorted. In order to keep this info online I post here a copy of the files from chapter 22, the pdf file of that chapter and some sketches
wistiti
Quote from: marathonman on July 30, 2016, 08:49:13 AM
This is my circuit i am presently working with if you must know.
drawn for simplicity and understanding.
Thank you!
Do it show a "Split/gap" on the core?
marathonman
Split but no gaps. if you have to cut the core secure it with 4 pieces of flat bar on either side of cut, top and bottom then secure with flat head bolts. make your cut, then take some resin and reattach. when dry it would be good with a layer or two of glass cloth and resin so it doesn't fly apart from the pressure and hurt some one. then make your bobbins (from experience).
ps. Hanon,  it sounds like Utkin has his device stuck where the sun don't shine. doesn't bother me a bit because i never followed him anyways. i have dedicated my life to Figuera.
MM
hanon
An interesting reading about scalarbeamer and its polarity:
http://www.gocs1.com/gocs1/Psionics/SCALARBEAMER.htm
Gennady Nikolaev : "...in the space where the the total vectorial magnetic field of two magnets is equal to zero, the total value of scalar magnetic field of two magnets is  maximal."
Doug1
Hannon
The condition to two fields in respect to time and strength are why it is zero. Two objects exerting the same amount of pressure on each other cancel out in the middle while the force if the two subjects are elastic will expand in the only direction left which is out in the direction where no force is applied. Thats not what is happening in the generator exclusively the force is not equal in respect to time or strength except at the minimal level to do away with the additional time to build up sufficiently at the rate of speed required. Reversal takes time and magnetic friction generates heat none of which are useful except to cook food or heat water.
I feel for Vlad he should have chosen a better venue.
