0 Members and 68 Guests are viewing this topic.
Seeking4thetruth
Quote from: marathonman on July 30, 2016, 08:49:13 AM
This is my circuit i am presently working with if you must know.
drawn for simplicity and understanding.
Thanks for the diagram, MM.
marathonman
Quote from: Doug1 on July 31, 2016, 11:15:21 AM
Hannon
The condition to two fields in respect to time and strength are why it is zero. Two objects exerting the same amount of pressure on each other cancel out in the middle while the force if the two subjects are elastic will expand in the only direction left which is out in the direction where no force is applied. Thats not what is happening in the generator exclusively,  the force is not equal in respect to time or strength except at the minimal level to do away with the additional time to build up sufficiently at the rate of speed required. Reversal takes time and magnetic friction generates heat none of which are useful except to cook food or heat water.
I feel for Vlad he should have chosen a better venue.
But at that minimal level, allowing each electromagnet to retain relatively high magnetic field strength without sacrificing efficiency that is normally associated with AC.
it is maintained across the entire space occupied by the secondary allowing the E field to be expanded and doubled in strength.
S4T; you r welcome.
the pic below is what i am talking about when taking precautions when cutting laminated cores.
MM
marathonman
Sorry to be off subject.
Hanon; the link to Bendini is exactly as was this device used for communication purposes.
pic below.
Doug1
Back on topic lol
I can only conclude based on the amount of info available people do not know or understand the difference between a transformer and a generator. Until you do you will only be able to make transformers.
ignacio
doug1:  can only conclude based on the amount of info available people do not know or understand the difference between a transformer and a generator. Until you do you will only be able to make transformers
Sólo puedo concluir en base a la cantidad de información personal disponible no conocen o no entienden la diferencia entre un transformador y un generador. Hasta que lo haga sólo será capaz de hacer los transformadores
!!!!!!!!OK!!!!!!!!!!!
