0 Members and 36 Guests are viewing this topic.
darediamond
Quote from: forest on August 04, 2016, 02:37:09 AM
Can you build variable frequency pure sinewave inverter ?  :-( it's not that easy.
Forest, the world is a global village. Simply go on to www.Fiverr.com to contract the build of a variable frequency pure sine wave inverter to an electronic Engineer on that site.
You simply go onto www.Aliexpress.com and buybtye components from one single Single Seller on the website and getbitbshipped to your outsourced be left tonic Engineer on www.Fiverr.com
One the E.E person receives the components from China and completes the job, he or she will then later ship the completed Job to you at wherever you are in the world.
You begin this process by postinhba Job or Offer on fiverr .com
You can even limit region of applicants so as to make things easier and faster.
To make an Inverter Variable Frequency, justvput an Adjustable Resistor on the output frequency leg of the IC on the board of the Oscillator Circuit simple.
The attached circuit produces pure sine wave.
Sam6
Marathon Man
#3811 on: July 28, 2016, 11:54:32 PM ยป You said you would PM me regarding methods you use for your 20KW unit. Great! How do you go about that? Unless you have some other method you can use my email...  briceelectric@yahoo.com.
Thanks in advance for your help.
Sam
NRamaswami
I'm disappointed to see the abusive language of Mr. Marathonman.
I have tested the geometrical pattern of the electromagnetic core with identical poles opposing each other and connected through a straight bar. Zero wattage. The Part G is a current interrupter which makes the current supplied interrupted current or pulsed DC input.
Significant output comes only if the poles are NS-NS-NS in a straight core as shown by Figuera.
I'm in the midst of handling a few Litigations and few more upcoming ones. I however will try to arrange for a video of the coils and show how the  polarity works in a straight core. Once the video is posted showing NS-NS-NS works and NS-NS-SN does not work, the argument and the abusive language must end.
If was not difficult to make videos earlier but we did not know what would be the effect on the cameras as the electromagnets we used are large.
If I have learned one thing it is this.. Magnets have their own way of action and we need to understand that to make electricity from them. If we do not go along with them, nothing can be done. To learn that we need to do a lot of experiments as the disclosure on magnets are very basic.
Actually there are only two principles to be understood. If opposite poles are facing each other, if the Magnetic field moves horizontally the electrical field moves perpendicular to the magnetic field but the magnetic field moves in an orderly way. Here the force is attractive between the opposite poles.
When Identical poles are facing each other the magnetic waves are dissipated in all directions as the force is repulsive. In this situation the best mode of taking the output is to create at least four coils which are perpendicular to the magnet in the middle of the identical poles and each arranged perpendicular to them. Then the magnetic field moves through the + shaped core as that is the easiest path. This is not shown in the patent of Figuera filed in 1908. Therefore the polarity is simply NS-NS-NS
I think a picture speaks 1000 times more powerfully than words. A video would speak a million times more powerfully than words. Please give me some time and I will have this organized.
Regards,
Ramaswami
Cadman
Ramaswami,
Part G is a splitter of current. Says so right in the patents.
QuoteI have tested the geometrical pattern of the electromagnetic core with identical poles opposing each other and connected through a straight bar. Zero wattage.
Then please explain this https://vimeo.com/155371838
which is found here on Hanon's page https://figueragenerator.wordpress.com/my-interpretation/
As you said "A video would speak a million times more powerfully than words."
CM
hanon
The problem with Ramaswami and Darediamond is because they are just using pulsed DC or AC to feed the generator. They did not have ever used the two signals created in the commutator properly built. Therefore they just have results with North-South polarity. With North-North they have null results with pulsed DC or AC as expected because they are not moving the fields. North-North requires the use the comutator described in the 1908 patent. Period.
I do not know how Ramaswami says that North-North, or South-South, does not work if he have never built the commutator as the patent describes. And he just repeat and repeat that the commutator is just to pulse the current. This is totally false. Also are false some statements done by Darediamond some days before telling that the commutator may be sustituted by a sine wave inverter. False. Please study the commutator.
