0 Members and 51 Guests are viewing this topic.
hanon
Doug1
 MM
I dont need to tell someone they did a good job they will know if they did for themselves. People who need a pat on the back for showing up to work are annoying. Personally I would be happier if they do not show up because they tend to do the least amount of actual work and take the credit for all the work done by all the people who did.
  "Could you.please.point to one that uses.such geometry in the Whole world?"
YES ! the Figuera device you idiot, unlike ANY generator in the world.
   All of them work off the same principles the same rules.Clemente just got rid of rotating the magnet but kept the changing magnetic field with the strength required to produce a viable output. That in itself should be enough to figure it out. Once you understand a rotating generator you should be able to come up with a way the same way Clemente did. So easy a child could do it. Remember that statement?
darediamond
Quote from: Doug1 on August 13, 2016, 08:45:20 AM
MM
And you are not even doing the rigth work. Are you?
"Clement just got rid of rotating the magnet but kept the changing magnetic field"  And yes that would now.mean he bucked the Primaries or made use of N to N or S to S  to achieve rotating magnetic field?
jegz
Dare & Rama. We are all here because we are looking for answers ..part of that includes having differences in opinion and that's perfectly fine.Its obvious Marathonman enjoys using foul language and will look for any opportunity to do so....even call someone nigger just because of a circuit diagram.  please be the bigger man and stop responding ..keep tinkering ..that's where the rubber meets the road  ..I wish you all the best
Hanon, as much as you may hold the view that this thread is being hijacked, think of Don Smith or TK who took Tesla's ideas and coupled them with technologies that were not available to him at the time and in the process improved them...Which is why the idea of using AC instead of part G could be feasible..as there is motion of magnetic flux but one where the B fields of the inducers are aproaching and retreating (assuming N....N configuration)..whether this is more efficient or not , only time will tell...but its no reason to stop asking questions..bottomline flux cutting is still achieved, its now only a matter of figuring out how to strengthen the inducer magnetic field strength for the least input possible.
darediamond
Quote from: jegz on August 13, 2016, 01:56:47 PM
Jegz, thank you for the nerve cooling words.
I might be wrong, but base on the 2 test I have done, the only way To Strength the inducer magnetic field is via application of Serially Connected Twisted Multifilar Coated Copper Wire.
Yet another way additionally is to wind the Primaries in Spiral . God if you do this, you gonna get Extremely Powerful Flux or Inducer Magnetic Field with low input although low input to the primaries is determined by the amount of Frequency you apply. With higher frequency application, what you gonna achieve is reduction in starting and running current and this will pave way for a Self runner system with ease.
The catch in Multifilar wire is that asnyou dive the wire further you will be increasing the Flux or Magnetic field it will be generating.
Praically this is whatbis mean:
Let say you bougth a 2kg of AWG#31 which is 0.30mm in diameter. If you divide it into 2 part, you will have 1000grams per part.  If you divide it into 20 parts, you will have 100grams per part but if you divide it into 200 part or STRANDS, you will have 10grams per part or strands.
Now if you twist 2 part together and use that to make your emag, the flux strength will be extremely low to the flux strength of 20 strands and the flux strength of 20strands will be extremely low to the one of serially connected twisted 200 strands which it strands are 10g each.
You can se that each level makes 2kg still. And even if iu apply he same voltage at beach level or part, you will not get the same Flux nor Magnetic field strength.
I have tested whatbis stated above.
640Ohms is the ohmic value of 2kg of AWG30 or SWG28 and that needs a minimum of 500V AC or.DC.
