0 Members and 75 Guests are viewing this topic.
darediamond
Quote from: Cadman on August 18, 2016, 10:59:22 AM
darediamond,
I have a question for you that relates to the subject matter of this thread, in particular the 1908 and later patents.
Imagine a hypothetical inducing coil as depicted in the patents.
The coil has a core with 32 cm^2 cross sectional area perpendicular to its length.
There are 500 turns of  wire on this core.
10 volts DC and 1 amp of current flow through this coil.
Suppose this coil produces a flux strength of 24000 gauss which is used to induce an emf in the adjacent secondary y coil.
Without adding any magnets or additional coils, or changing the voltage or amperage flowing through the coil, or the number of turns of wire, how can this coil be modified to increase the flux strength to 48000 gauss?
I know how I could accomplish this but I am curious as to what method you personally would employ.
CM
I have made a post in which covers answer to our question. Search for it. Granted I have few posts posted on his thread so you should be able to find your way via.
Goodluck Mr.
Cadman
A couple of members are having trouble getting the autotransformer book from Google so I have uploaded it to overunity.com/downloads under this title:
AUTO-TRANSFORMER DESIGN by Alfred H. Avery
CM
Cadman
Quote from: darediamond on August 18, 2016, 01:26:16 PM
Goodluck Mr.
No thank you. I asked you for your view on a pertinent question but if all you have to offer is attitude then you can keep it for yourself.
darediamond
Quote from: Cadman on August 18, 2016, 03:07:30 PM
I know how I could accomplish this ......."
Those are your words there. So what benefit will my strategy add to yours?
Learn to device better intelligible way of toying with a fellow man Intelligence.
Goodluck
darediamond
Quote from: NRamaswami on February 15, 2014, 03:44:42 AM
To Farmhand and Shadow:
You are off the mark.. What is the purpose of the rotary device..To create an interrupted or alternating current that will change signs when it moves from one point to another point.. When your mains supply is already alternating current the rotary device today is not needed and remove the rotary device and the resistor setup and just feed directly from the mains.. That way you get sign wave and 50 Hz or 60 Hz current automatically. Figuera did not disclose the best method of carrying out the invention and so he disclosed a weakest method of carrying out the invention. His disclosure substantially hides one important point. Both the primary electromagnets must be of equal strength for the device to work best. They should not be of weaker compared to one another. Of course his set up made the two electromagnets alternately stronger and weaker and we did not test that but in our tests we got the best results only when both the primary electromagnets are of equal strength.
Simply this is an amplifying transformer. Two step down transformers  acting as primary electromagnets set up in such a way that the opposite poles of the two are facing each other and in that place you place another secondary of many turns to step up the voltage. Then what you get is both amperage and voltage increase. In the step down transformers, amperage is increased and in the secondary between the two step down transformers voltage is increased. When all three secondaries are connected in series you get both a voltage and amperage increase. This is as simple as that.
The set up is NS - NS - NS  The bolded outer electromagnets are the step down transformers where the secondary is placed near the core and the primary of many turns and preferably bifilar or trifilar or quadfilar is wound upon it. I used Quadfilar primary. Secondarly is a single wire. In the middle electromagnet you increase the number of turns many times and many layers. In all I used about 1300 meters of 4 sq mm wire out of which about 500 meters were primary and 800 meters were secondary. The electromagnets were built on a plastic tube 4 inches in diameter and 18 inches length. We used soft iron rods to create the electromagnets. 3 such devices were placed in the NS-NS-NS configuration. That is all that is needed to test and verify the results. This device works.
However be careful. When you give 220 volts electricity the electromagnets take about 7 amps but the output is really dangerous 630 volts and 20 amps output..You may get more or less depending on the number of turns and depending on the input voltage.
This is a modular device. Figuera called it Generator Infinity. This is true. If you use the output of the first module to feed the second module and the output of the second module to feed the third module you are going to get increasing voltage and amperage. Any one can test it and see the results themselves. But be extremely careful as the resulting voltages are deadly as the amperage also is very high.
Making the device self sustaining is of no problem really. The output is high voltage and higher amperage. Secondary current will flow in the direction opposing the primary current. When you provide a step down transformer to use the electricity, the output of the step down transformer will flow in a direction oppising the feeding secondary current. So the output of the transformer will be in phase and synchronise with the primary input. Now all you need is a make before break change over switch and change the source of feeding current to the output of the transformer. A part of the transformer output is enough to keep the unit running. Rest of the transformer output is given to load. The original feeding current is removed and the system will continue to work. I have not done this part. But I think given this information any number of posters here can replicate the results.
If you use this in an Electric car, the car can run any amount of distance. Only thing is that we need to convert the AC output to pulsed DC output to run a DC motor or may be use a capacitor to make it a perfect DC current to run it. A Battery, an inverter and this set up and then converting to pulsed DC through a bridge rectifier and then a capacitor to make it perfect DC is all that is needed. May be use a solar panel to keep the battery charged. Since the battery would be used only at the starting time, it will not diminish and in any case the alternator present in the car will keep charging the battery.  This is an extremely simple device really and I do not know how you people who are all experienced electrical engineers have missed the mark.
Let me see comments that will call all this a mirage. But do test it yourself and check the results before calling my results bad..
