0 Members and 51 Guests are viewing this topic.
forest
Transformer is really not transformer but saturable reactor. The essence is flux linkage and common core in the sense that the load applied on secondary effect the saturation of core which effect primary current. This feedback mechanism is the problem , second one is Lenz law and so on....
darediamond
Quote from: NRamaswami on August 21, 2016, 01:11:04 PM
Sir..
What I observe is this. .
Here mains voltage is not constant.  It flutuates between 190 to 220 volts. In the same set up output of secondary is 30 volts when input voltage is 220 volts. Output of secondary drops to 18 volts when input voltage is 190 volts. We have 50 hz here.
Similarly if you increase the voltage to 1000 volts frpm 100 volts output voltage will shoot up. Secondary resistance being constant when secondary voltage is increased the amperage also raises. Amperage is based on secondary wire thickness and amazingly thickness of secondary insulation.  I understand thick wire producing higher amps but I do not understand the insulation part. Information on insulation is available in Daniel McFarland Cook patent and in Joesph Cater book. No where else.
Don Smith wrote double the voltage quadruple the output. This is true for secondary.
I cannot write on specific numbers as I have not experimented andobserved but if you increase primary voltage secondary is bound to increase. If you are inclined to experiment please pm me.
Doug..Intensity of magnetic field and input voltage are the two things that matter from my
observations. Please explain in simple English for people like me to understand if you feel otherwise.
Ramaswami
For every 200ohms resistance, minimum of 500V is needed.
When you exhaust the maximum voltage a coil can bear, the remaining factor or property that will allow you to continually generate high magnetic field is Frequency which is universal. The needed voltage of a coil have something to do with it Maximum Ohmic Value or Resistance Value. But the maximum applicable Voltage is determined by the Resistance and LEVEL OF WIRE.INSULATION.
Normally, you would want to stay below the radar so as not to get your coil burnt.
The Maximum frequency your coil can bear is determined by the type of Core of your Coil. Air core Coils have little or.NO LIMITATION to the amount of Frequency it can withstand. While Iron Core is the opposite.
However, to use generally safe frequency of 60hz to drive your coil at the applicable voltage/resistance level and still generate massive Magnetic Force or Flux, then Twisted Serially Connected Wires must be applied. But would this allow for a self-runner? Arguably No is the answer because low frequency of 60hz will make the primaries to consume High Amperage which the Battery can not easily absorbed even if the secondary winding will provide it in 10 fold or more .Butteries have charging current and discharging current limitations. So to achieve overunity using batteries to power your device, it is require that your Primaries must consume below the maximum charging current of your battery or Batterry bank.
The Higher the input voltage the higher the output voltage but the effect will not be Extremely Powerfull as when the other factor is applied. The factor is increment in frequency.
When you coninually increase the  rate or speed of switching, the Primary will continually drop input current but increase the more Output AMPERAGE. AND IN TOTAL, OUTPUT POWER IN WATT!
You need no HIGH INPUT CURRENT TO Generate High Magnetic Force you simply need ***HIGH FREQUENCY*** HIGH VOLTAGE*** and Optionally Twisted Serially Connected Multifilar Wire ( TSCMW).
Radiation emitted at high frequency is not a barrier, Simply place your Derive in an Alluminium Box. You can optionally perforate it for proper ventilation.
How big and permeable your core is determines your applicable maximum amount of frequency to your coil.
Now a days, you need Pure Sine Wave inverter (motionless Switch) to Run Overunity Devices. So building one that have variable frequency is a MUST.
NRamaswami
So Mr. Forest
Once core is saturated primary will not draw further current. Right.
Core saturation problem solved.
Core heating problem solved
Lenz law problem solved
Controlling the EM radiation and reducing it is alredy solved and solutions are available but it it needs to be kept in secluded areas.
Feedback problem can be solved easily but there are valid concerns about drawing excessive energy from environment. Figuera solved it using very low frequency if the patent info is genuine.  I think it is highly edited info. So I cannot rely on it. There is no info on feedback circuit in any patent.  But there are other methods.
If Time money and health permits I will do it in future.
Ramaswami
If the Figuera device is a static machine(except the commutating function doing motor)
cutting the lines and the angular momentum, an example (one from the Flynn papers citing docs):
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=WO&NR=2009112877A1&KC=A1&FT=D&ND=5&date=20090917&DB=EPODOC&locale=en_EP
The above-mentioned principles are also value for the Tran-energy machines without permanent magnet(s) in the core(s) of the magnetic circuit(s)
Keiichiro Asaoka : static dynamo machine ,no C.O.P. explaining
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990720&CC=US&NR=5926083A&KC=A
C.O.P. 1,8-4,8 ;with permanent magnet (Figuera device without)
https://worldwide.espacenet.com/publicationDetails/biblio?CC=JP&NR=2003102164A&KC=A&FT=D&ND=3&date=20030404&DB=EPODOC&locale=en_EP
We know the cycle duration from batteries and capacitors/condensators :
what have been the working quantities in hours of the Figuera/Buforn device ?
The average motor/electro-imans/magnets service life in the beginnings from the last century ?
We are reading about 20000 W output : how long ? Economical numbers ? HF pulsed DC output ?
Pulse : Dirac surges and https://en.wikipedia.org/wiki/Dirac_sea
                                                electron-proton-positron (to plasmon-ics)
The development of quantum field theory (QFT) in the 1930s made it possible to reformulate the Dirac equation in a way that treats the positron as a "real" particle rather than the absence of a particle, and makes the vacuum the state in which no particles exist instead of an infinite sea of particles. This picture is much more convincing, especially since it recaptures all the valid predictions of the Dirac sea, such as electron-positron annihilation. On the other hand, the field formulation does not eliminate all the difficulties raised by the Dirac sea; in particular the problem of the vacuum possessing infinite energy.
Modern interpretation:
Conclusion:
additive to "positive energy machine"(heat) we will develop "negative energy machine"s (cold)
quantum field converter: energetic electron to thermic electron : eV-dependance
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4720642A&KC=A&FT=D&ND=3&date=19880119&DB=EPODOC&locale=en_EP
Because electron became named  -not by me,but by international convention- ion :
                                            thermic + ion = thermion
                                            hot and cold "electricity"
                                            with  PTC/NTC
Cadman
Jeez lancaIV,
I thought you were going to do a systematic study and breakdown of the Figuera patents. ?
We really don't need to comprehend every other generator patent, dirac surges,  quantum field theory, the Dirac sea, electron-positron annihilation, negative energy machines, ad nauseam.
Focus man! :D
CM
