0 Members and 23 Guests are viewing this topic.
                                       Cadman : #4030 ! #4031 !
                                    what-you-read-is-what-you-get ?
NRamaswami
Sir. .That 20000 watts with 300 Amps means about 67 volts. I tried to do it but it is not working.  300 volts and 70 amps could be credible or even thevreported 550 volts at 35 amps is very credible. Will require a 10 sq mm wire to handle that current.
Ramaswami
Cadman
Quote from: lancaIV on August 23, 2016, 01:07:24 PM
Analysis paralysis !
Quote from: NRamaswami on August 23, 2016, 01:25:39 PM
Sir. .That 20000 watts with 300 Amps means about 67 volts. I tried to do it but it is not working.  300 volts and 70 amps could be credible or even the reported 550 volts at 35 amps is very credible. Will require a 10 sq mm wire to handle that current.
Ramaswami
Ramaswami, this VA-relation is new for me ! Which publication ?
If it is written 100V and 1A to 300A and totally 20000 W then the tension has to be in the 67V range( pure mathematical by dividing,not VAr including et cet.)
Questionable: 1928 15 hp for heating , Canaries Islands ? Un Palacete mucho grande ?
https://en.wikipedia.org/wiki/Canary_Islands climate
Average low °C (°F)
15.0
(59)[/color]
15.0
(59)[/color]
15.7
(60.3)[/color]
16.2
(61.2)[/color]
17.3
(63.1)[/color]
19.2
(66.6)[/color]
20.8
(69.4)[/color]
21.6
(70.9)[/color]
21.4
(70.5)[/color]
20.1
(68.2)[/color]
18.1
(64.6)[/color]
16.2
(61.2)[/color]
18.0
(64.4)[/color]
In the european south home heating has not been common.
In my chamber there is not a heater,2016 !
But pardon,Canaries make part from the african shelf ,only geopolitical spanish-european !
Patent publication: Trustable numbers ?
Quote from: Cadman on August 23, 2016, 02:32:24 PM
Cadman,the Figuera/Buforn Jacas device is a "Maer",something like a "dreammachine" with absolutely
no detailed description for DIY.    "terra incognita"
paralysis: parar =stopping/hold on
Ja=yeah,introducing educated knowledge and quantum possibilities in these concept,
a 2.kind ppm-machine
