0 Members and 27 Guests are viewing this topic.
NRamaswami
Quote from: lancaIV on August 23, 2016, 02:47:00 PM
Ramaswami, this VA-relation is new for me ! Which publication ?
If it is written 100V and 1A to 300A and totally 20000 W then the tension has to be in the 67V range( pure mathematical by dividing,not VAr including et cet.)
Questionable: 1928 15 hp for heating , Canaries Islands ? Un Palacete mucho grande ?
https://en.wikipedia.org/wiki/Canary_Islands climate
Average low °C (°F)
15.0
(59)[/color]
15.0
(59)[/color]
15.7
(60.3)[/color]
16.2
(61.2)[/color]
17.3
(63.1)[/color]
19.2
(66.6)[/color]
20.8
(69.4)[/color]
21.6
(70.9)[/color]
21.4
(70.5)[/color]
20.1
(68.2)[/color]
18.1
(64.6)[/color]
16.2
(61.2)[/color]
18.0
(64.4)[/color]
In the european south home heating has not been common.
In my chamber there is not a heater,2016 !
But pardon,Canaries make part from the african shelf ,only geopolitical spanish-european !
Patent publication: Trustable numbers ?
Sir..I do not know climate in European countries.
The 550 volts ibfo is from the 1902 press clipping.
The 100 volts 1 amp input and 20000 watts output at 300 amps I think is in the last patent of Buforn. That would require 10 coils if 10 sq mm to be wound in parallel and connected in parallel.  For this the core must be very large.
On the other hand 670 volts and 30 amps is easier to do and then can be stepped down to ueable electricity.  It is easier to do it and a six inch dia and 18 inch long secondary core can do it. If the input voltage is higher and permanent magnet was used for primary then primary amp can be lower. I would think 1000 volts input at 1 amp wth permanent magnet core in primary can do this easily if we have large cores.
Higher the input voltage higher the secondary wattage. Observed by me. Permanent magnets core would avoid the need for electricity to create electromagnets. We already know by using multifilar coils and plastic uronsheets and plastic between layers in primary current drawn can be considerably reduced.
It is quite possible that the resistor array was used to boost voltage in the ciils from a battery source as the rotary device made the dc into Ac. it could well be that the batteries used are total of 100 volts.   It is possible that the srep down transformer was used to again feed the rotating device durectly eliminating the need for batteries.
The Engineering student who works for me now tells me that the rotary device is a special commutator and if properly bult will be sturdy.  We could not build it.
The first 1908 patent is a disclosure document. Subsequently this could have been run.
The questions are us the input voltage boosted to 1000 volts and if permanent magnets are used in primary.  If the answer is yes the results of 20000 watts I can assure you are doable. Figuera says very little current is needed to excite the primary.  That is what makes me think he used permanent magnets.
What type of steel is the best permanent magnetic material. Can you please find out and advise me.
Ramaswami
I think 420 gradevsteel rods if stronly magnetised once will not be demagnetised until and unless we heat them above their curie temperature but my knowledge is limited here.
Looking for the Oersted/Gauss-values from permanent magnets in the beginning of the last century
I mean that commercial C5/C8 Ferrite pm will do their job,
alternatively as DIY-solution  http://www.instructables.com/id/Permanent-Magnets/ .
But: this is not the original -no permanent magnets- Figuera/Buforn version
Moderatly I would give the advice to begin a new thread : semi-static F.-B.-R.(amaswami) dynamo ;)
http://phys.org/news/2016-08-physicists-discovery-nature.html
Citing physicists' understanding of the standard model, Feng speculated that there may also be a separate dark sector with its own matter and forces. "It's possible that these two sectors talk to each other and interact with one another through somewhat veiled but fundamental interactions," he said. "This dark sector force may manifest itself as this protophobic force we're seeing as a result of the Hungarian experiment. In a broader sense, it fits in with our original research to understand the nature of dark matter."
Buforn Jacas wrote in the 1914 papers about the"new physics"-view of electro-magnetism and matter .
(Also as argument for the unknown machine-internal process)
Hundred years later the search and findings do not stop.
In the labs measurements are in the "pico"-level.
Cadman
We interrupt this program for a brief musical interlude from the 'Man in Black' Mr. Johnny Cash!
"I hear the train a comin'
It's rollin' round the bend
And I ain't seen the sunshine since, I don't know when..."
We now return you to your current program "All there is to know about everything"
Smile
not copper but iron windings: https://www.researchgate.net/publication/2984608_Eddy_Currents_Theory_and_Applications
eddy currents / load  dis-/advantage
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820302&CC=US&NR=4318019A&KC=A
rotor/static core ~ dynamotor
http://rexresearch.com/alxandr/3913004.pdf
Cadman, 50 Hz x 60 sec by 220 V (European grid)         for 3000 RPM standart     2016
               60 Hz x 60 sec by 110V                                    for 3600 RPM standart     2016
Cadman,you know it all : 1928 ? Pardon,I do not know it ! Figuera-Buforn generator/ load inrush current relation ?  Only resistive load ?
