Cadman,this are the questions ! Search range !? Only Spain or Europe or world-wide ?
Answer which would only get : several different types !
I would say,each machine: unikum ,1928 ! No industrial mass production norm !
powdered ferrite related :a little mad idea -not from me- is to treat minerals like " sea animals",aquarium-like  : feeding them !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931111&CC=DE&NR=4222678A1&KC=A1
recitating Prof. Szabos view : an "electro-magnetic fuel"
soft ferrite related:
powdered ferrite to ferrite block and if you use the material bonding resonant frequency you will get this machine effect :
http://www.igus.eu/wpck/6328/app_vector10_Nierensteinzertruemmerer?C=DE&L=en
or welding parts = arc welder function
Figuera device: interview 1902
https://archive.org/stream/Clemente_Figuera/Interview_Figuera_1902#page/n1/mode/2up
"with the power to run a motor developping a force of twenty horsepower"
electric motor efficiencies 1928 to get +/- generator output
Cadman
Quote from: lancaIV on August 25, 2016, 12:50:41 PM
Search range:
Elementary Dynamo Design W. Benison Hird 1908
Dynamo Electric Machinery Silvanus Thompson
Fourth Edition Vol I 1893 ?
Fifth Edition Vol II 1896
Seventh Edition Vol I 1904
Auto-Transformer Design Alfred H. Avery  1909
Search range: http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/
Dates: 2014 - 2016
Key words: Doug1, marathonman, Hanon
Search range: https://figueragenerator.wordpress.com/
I am 100% serious
CM
serious ?  :o
"... All parts have been built separately in various workshops(mean offices) under the management
of the inventor,..." Delivered from France,Germany and so on !
In the papers are only cited: Pixii ( from wikipedia: electrification)
Around 1832, Hippolyte Pixii improved the magneto by using a wire wound horseshoe, with the extra coils of conductor generating more current, but it was AC. André-Marie Ampère suggested a means of converting current from Pixii's magneto to DC using a rocking switch. Later segmented commutators were used to produce direct current.[4]
William Fothergill Cooke and Charles Wheatstone developed a telegraph around 1838-40. In 1840 Wheatstone was using a magneto that he developed to power the telegraph. Wheatstone and Cooke made an important improvement in electrical generation by using a battery-powered electromagnet in place of a permanent magnet, which they patented in 1845.[5] The self-excited magnetic field dynamo did away with the battery to power electromagnets. This type of dynamo was made by several people in 1866.
NRamaswami
LancaIV. .Sir. .
Can you please the links for the specific patents that you indicated in your last post. The principle stated is correct but the circuit needscto be changed if we change the geometry.  We can do away with the rotary device totally to achieve the same result claimed in the Figuera bpapers. I thought it hides only one component but it seems to hide two if we change the geometry.
Please post the old patent links of pixxi and others thatbused permanent magnets to boost output.
Ramaswami
