0 Members and 27 Guests are viewing this topic.
What do you really want,Ramaswami ?
How I wrote and think: nobody will ever build a 100% Figuera/Buforn engine/generator but the idea is to enginer a machine based by
the Figuera/Buforn work principle and process result !
                               Magnetic field force amplification and field lines crossing to get amplified electric power !
              You explain good teste results power related,but you do not write about material behaviour/consumption !
        Material as solid fuel !
                             Do not be afraid: also all other energy converter are not "physically imortal" !
                     Solar cells 30 years periodically use( sun ),but only 3 years permanent use (light box)
                                                    drop-away plastic cells: 1/2 year by periodic use
                                                   Batteries: 90 days(lead) up to several years(redox)
                                                               per KWh-production price :
                                      recycleability and earth rock material mining quantity dependant !
                                       You will have to get your results repeat-and measureable.
With 220 volts in primary I was able to get up to 350 volts in secondary in the center slone or about 70 volts and good current that can light 10*w [/size]200 watts lamps. :[/size]
        intensity ? power consume/conversion
pulsed power and human eye: http://www.google.com/patents/US5130608
Since the useful energy is expended mainly during the pulse width but not during the resting period between pulses, which is relatively much larger than the pulse width, [/font][/size]yet too short to be perceptible to the human eye, considerable energy can be saved while nevertheless maintaining brightness of illumination.
                                                   less input seems to be higher input : attention paying !
                               Begin with < 1000VA result experiments,let this examine officially ,
                                        later > 1000 VA range experiments (especially for the India power consumer) !
                                                  As basic teste configuration :                     [/size]
                                                              Which VA input ?[/size]
".... If we put permanent magnets and increase the voltage to 880 which my wires can handle secondary should increase to 280-300 volts and 10-12 amps. ..."[/size]
With less/more VA input ? remark the results ! heat measurement / curve
                                 material vibration/(thermal)noise ?!
                               Think and visualizing tools :      http://www.coolmagnetman.com/magvisual.htm
                                        It is classical enginneering using quantum science work range
Thinking about Figuera/Buforn given numbers:
20 horse-power ,continous or peak value ?,electric motor serving
        gear-ed/-free ?
1902-1914 there has not been an industrial production standart
(neither national nor international)
NRamaswami
Sir..
This is a very expensive project.  Each test required a team work.
I do not understand your comments on material as fuel or material consumption. Material remains intact.
If we provide current to make primary  electromagnets and from there we try to generate electricity from secondary most of the time we are biund to fail unless we reach core saturation.  On the other hand if we use partially magnetised permanent magnet core  in primary then we needcto give high voltage and lower amperage only to get very good output far in excess of input.  This is quite simple and straight forward. Using Ac input multifilar coils and a mild permanent magnetic core in primary we can easily achieve this. But none will accept this.
How we can make this in to a self runner is not clear to me. There are theories but I have not even tried ascthey are said to be very dangerous to conduct. I cannot take risks.
Somehow 15% of soft iron used by s has become permanent magnets.  Very mild but not clear to me how. Professor who lokked at my results wanted me to test each rod for magnetism and we took a long time and got about 75 kgm of soft iron rods of different magnetic strength.
I cannot say why the same rod is stronger at one end and weaker at another end. Their magnetism is removed only by heating. Somehow magnetic remanance has formed in soft iron rods but not in all and even in the same rod it is varying in places.
I will be working on other principles as time and money permits and subject to availability of team.  Whatever I indicated can be verified easily.
In fact Mr. Cadman accepted that He tested the NS NS NS variation suggested by me and found it to be cop <1.
There is nothing surprising in it as he used single module and used current to make primary electromagnets.  If he has used higher voltage input and permanent magnets he eould have got bettee results.
I find my results and observations to be different from a lot of accepted info stated here and we have replicated again to verify our results.
You can test yourself as you indicated you have done extensive research. You can increase or decrease the input voltage and verify how the output is affected.  I would also suggest that use multifilar coils in primary alone. In secondary we need to use a single highly insulated thick wire.
Except for the self runner part I have verified the other results.
Generally speaking Nature generates electricity in two ways. Electrostatic and Electromagnetic.  If we combine both of these methods probably it is possible to build self runners but I do not have the technical expertise to do all these things nor the funds. I am also exhausted.
Ramaswami
Hello Ramaswami, I read and think also under the line !
Tiger and cat , Tami and Tamil Nadu (South India and Ceylon/Sri Lanka), about "old man" and charity and "I am also exhausted".
What you are  doing makes today part of the microphone/loudspeaker/amplifier/tuner/receiver/ex-LP to Cassette to Disc-Floppy to CD-to DVD to stick high fidelity technology : main interests compression and micronization
                             Information technology but also as entertainment tool
Yes,R&D costs much,100000 US$ for the first development stages a real number, industrial pieces using and engineers/Uni labs controlled.
If you have good results go to the TATA Group and/or the Reliance company(wind power) ,they can afford the needed research for industrial standartization and have technical and economical/comercial experience. (investments risc and losts included)
Electrification from the rural area can become accelerated by such  static e-/pm- generator disclosure !
Probably it is not a bad idea to apply an "utility model" of this device ! Before you publicate the concept to possible investors !
                       "federal/estate development agency"programs for rural poverty : existant ?
NRamaswami
Sir..You need not read under the lines. That is not necessary.
Regarding the old man appearing before me it was an experience. Many know about it. From the time he appeared my knowledge has increased manifold but finances have come down. If I have the same kind of finances I would have completed this project long back.
Nothing of the sort you mentioned would work here. Things are extremely corrupt here. Only if you have right connections and bribe people to their satisfaction things can be done here. If you donot have that money then you are stuck where you are.
Here Government gives free Electricity to farmers..One of my clients tried to do a generator from wasted water energy and feed it back to the grid. He made an invention which you can see at www.tmptens.com I took it to the Government and ultimately learnt that if there are big profits than very high bribes need to be paid even to be considered.
You are correct in understanding that I have not disclosed much. Majority of JLNaudin site is restricted to be viewed in India. The Gegene generator info which is high frequency and cannot be used to run motors and can only light lamps and heaters was off view to the Indian public in National security interests. This will not sell here.
What Figuera found and what I did is nothing new. It is called simple magnetic amplifier boosting the output. Hundreds of videos are probably out in the interenet. The point is that I made significant improvements.
As an additional note you can get 4 Run capacitors of 220 volts and 200 to 1000 microfarads and put them in series and connect the module of such capacitors in parallel to the primary. You will see that the primary input drops. You can place another such module depending on the output voltage ( voltage of capacitors to be four times the voltage of the output or input) and you will see that the output increases. I do not know why it behaves like this.
Electricity generation is actually quite easy. You can make it any where in the world with four Earth points. I think self runners can be made to work safely but Patrick has warned me that it can attract lightning strikes and one inventor in US was hit by lightening when he did that. Is the info true or not is not known to me but I have avoided taking risks. Standardization and commercialization is difficult. I probably have spent more than $1,000,000 in western labour costs and effort. It is not easy for you people to do it and here no one is bothered.
I was so curious about the Hubbard Generator. Turns out that it is a simple machine. Once started it can continue as there are no moving parts and only one component that can wear out.
Not even Dr. Moray was able to commercialize his invention. What can I do?
Probably things will change..But who knows when they would. We have to wait and see.
Regards,
Ramaswami
