0 Members and 42 Guests are viewing this topic.
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20121220&CC=DE&NR=102011111692A1&KC=A1
Wind concentration/velocity amplification technology                  related            to coil winding concentration/velocity amplification technology
also:
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=4&adjacent=true&locale=en_EP&FT=D&date=20140522&CC=DE&NR=102013010837A1&KC=A1
[0041]
The result according to the invention the new effect that a plurality of molecular electricity generators 30 includes a current collector 29 forming molecule, which is connected only via the flow opening 34 to the induction pipe 31st In molecular current collector 29 a rotational flow is produced. The molecular stream generators 30 direct the molecule flows 20 under pressure tangentially into the molecular current collector 29 a, so that from the excess pressure in the induction pipe 31 a rotational flow in the direction of outflow 38 is formed, in which the molecule currents 20 place over the flow opening 34 and form a molecule current coil 33rd A large number of molecular flow 20 results in a close-packed molecule current coil 33, so that the molecules are inductively aligned in the induction tube 31 to the outflow opening 38th The acting via the outflow opening 38 pressure of the atmosphere is then in the induction pipe 31 against the induced in all molecules moving force. Since the induction capacity of a molecule current coil 33 increases with decrease in their diameter, counter-currents can be safely ruled out by the induction pipe 31 by cross-sectional changes.
[200]
can be supported by calculation done a reasonably accurate estimate of the extra speed that must have induced a molecular current coil 33 jet flow 35th This accurate calculation methods may be developed in the course of operating experience. It has been found that a drive power of a molecular stream generator of max. 200 W sufficient to form a molecular stream 20 with a circulation Γ = 11.0 m <2> / s. A molecule current coil 33 begins at the end of Durchströmrohrs 32 and ends at the outflow 38th First, the theory induced additional speed is determined in the middle of the molecular current coil 20, after which theoretically induced additional speed at the end. Middle and top speed are added and the sum divided by two. The result is practically occurring average speed of induced jet flow 35th For example, if 45 ° lead angle of the molecule currents 20, 0.40 m diameter, 1.0 m in height and eight molecule flows 20 a molecular current coil 33 given, then there is a drive capacity of 1.6 kW.
[0043]
From the time-related angular momentum concentrations results in the additional velocity vz induced jet flow 35 with 52.44 m / s and a beam power of 11.047 kW. The ratio of drive power of the molecular current generators 30 to the induced beam power 35 is 1: 6.9. The number of molecules navigate through 20 goes straight into the calculation. Doubling the number of 16 molecules navigate through 20 would require only the assembly of 16 molecular stream generators 30 and would be limited only by the diameter of the power module 28th At constant design parameters, the additional velocity vz changes to about 114 m / s and the power of the induced jet flow 35 to about 88.4 kW. The ratio of the drive power of the molecular stream generators 30 to 35 induced beam power is inexpensive. This performance improvement results from the fact that the circulations of the molecule currents 20 spatially produce a higher energy density in the molecule current coil 33 and the induced additional speed vz enters the third power in the power calculation.
all clear : through compression stages ;  question now : acceleration : conventionally second power/potential
but here calculation by ,recitating,     and the induced additional speed vz enters the third power in the power calculation.
analog: calculation  electro-magnetical transformer ,static or rotoric ?
darediamond
Quote from: NRamaswami on August 28, 2016, 07:06:33 AM
Sir..
This is a very expensive project.  Each test required a team work.
I do not understand your comments on material as fuel or material consumption. Material remains intact.
If we provide current to make primary  electromagnets and from there we try to generate electricity from secondary most of the time we are biund to fail unless we reach core saturation.  On the other hand if we use partially magnetised permanent magnet core  in primary then we needcto give high voltage and lower amperage only to get very good output far in excess of input.  This is quite simple and straight forward. Using Ac input multifilar coils and a mild permanent magnetic core in primary we can easily achieve this. But none will accept this.
How we can make this in to a self runner is not clear to me. There are theories but I have not even tried ascthey are said to be very dangerous to conduct. I cannot take risks.
Somehow 15% of soft iron used by s has become permanent magnets.  Very mild but not clear to me how. Professor who lokked at my results wanted me to test each rod for magnetism and we took a long time and got about 75 kgm of soft iron rods of different magnetic strength.
I cannot say why the same rod is stronger at one end and weaker at another end. Their magnetism is removed only by heating. Somehow magnetic remanance has formed in soft iron rods but not in all and even in the same rod it is varying in places.
I will be working on other principles as time and money permits and subject to availability of team.  Whatever I indicated can be verified easily.
In fact Mr. Cadman accepted that He tested the NS NS NS variation suggested by me and found it to be cop <1.
There is nothing surprising in it as he used single module and used current to make primary electromagnets.  If he has used higher voltage input and permanent magnets he eould have got bettee results.
I find my results and observations to be different from a lot of accepted info stated here and we have replicated again to verify our results.
You can test yourself as you indicated you have done extensive research. You can increase or decrease the input voltage and verify how the output is affected.  I would also suggest that use multifilar coils in primary alone. In secondary we need to use a single highly insulated thick wire.
Except for the self runner part I have verified the other results.
Generally speaking Nature generates electricity in two ways. Electrostatic and Electromagnetic.  If we combine both of these methods probably it is possible to build self runners but I do not have the technical expertise to do all these things nor the funds. I am also exhausted.
Ramaswami
I am yet.to.test the NSNS theory but I powered.my multifillar coil with 200VAC and hold a magnet above it and viola there start to be a Vibration of the underneath Electromagnet. I turned to the other.sides, the vibration sprang up too indicaticating that the Polarity is ever instantly reversing from N-S to.S-N on each sides and thus cormirms that N-S to S-N makes a Motionless Motor.
Ramaswami, you need no magnet to reduce the inputs current. All you need is High frequency, High Voltage. And Ferrite Core.
darediamond
Quote from: darediamond on August 28, 2016, 02:09:33 PM
Do not get me.wrong, when I said N-S to S-N makes.motionleess Motor , I really mean The motionless  MoGen must be in attraction mode. Because it is only with.that that there can be really accelation of Electrons on the secondary copper wire windings
